crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Pump doesn't work
Either the pump will not slide at all or very little, or the pump goes through full range of motion but the gun does not cock.
Magazine isn't placed correctly
The Nerf Vortex Praxis has multiple safety features including a magazine disconnect that will prevent the blaster from firing or even cocking if there is no magazine inserted. Make sure the magazine is properly seated inside the magazine well.
Spring assembly is damaged
It is possible for the spring assembly to become damaged during use. The results of this could either be a broken piece jamming the assembly or the assembly being unable to prime after pumping. Replacement of the spring assembly may be necessary.
Trigger doesn't work
The trigger is either limp with no resistance or is stuck and won't pull. Pulling the trigger does not fire the blaster.
Jammed firing mechanism
The firing mechanism has become jammed either due to a disc becoming dislodged or a spring has come loose. There is a switch on the side of the blaster that will aide in the removal of jammed discs. Otherwise the blaster will need to be disassembled so the internals can be lined back up.
Gun cocked improperly
The blaster is not being cocked all the way. Make sure the pump handle is pulled completely to the end of it's track before firing.
Trigger assembly is damaged
The trigger assembly has been damaged and either a spring has come loose or a piece has broken. The blaster will need to be disassembled to replace springs or broken pieces.
Jammed loading mechanism
The blaster won't load discs but will still fire.
A disc is lodged inside the barrel
A disc has become stuck on the inside of the barrel preventing the blaster from loading another. The un-jamming lever on the side of the blaster should clear the disc.
The magazine isn't loading the discs
The magazine might be damaged and unable to push a disc into the loading mechanism. Check to make sure the magazine is not chipped anywhere. Replace spring if needed.
The blaster fires but the discs do not go far or even exit the barrel
When the blaster fires, the discs are not coming out with full force.
Dirty barrel
Dirt and debris can become lodged in the barrel, blocking the disc from exiting. Use water to try and wash out barrel, using pipe cleaners to dislodge and stuck large debris. Be sure to dry thoroughly after washing.
Damaged firing assembly
The firing assemble that holds the spring has become damaged causing the spring's energy to not be transferred to the disc. The blaster will need to be disassembled to assess the damage and remove any broken parts. Parts will need to be replaced or the whole assembly itself.
Damaged spring assembly
The blaster fires using a torsion spring that has become worn, diminishing the force it can exert. The blaster will need to be disassembled for the spring to be replaced.
Attachments will not connect to blaster
Attachments do not stay in place when trying to connect them to the blaster.
Damaged rail
The railing on top of the blaster has been damaged in some way and prevents the secure attachment of accessories. The small clip in the center of the rail will need to be replaced if broken. If the railing is chipped, the broken pieces can be super glued back into place or modeling clay can be used as a filler.
William Gainey
crwdns2935283:002/16/16crwdne2935283:0
37 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
IUPUI, Team 3-1, Harley Spring 2016 crwdns2935289:0IUPUI, Team 3-1, Harley Spring 2016crwdne2935289:0
IUPUI-HARLEY-S16S3G1
crwdns2936753:030crwdne2936753:0 47
crwdns2959996:0crwdne2959996:0 6,660
