Motorola V3c Troubleshooting
The screen won't turn on
The phone may be off
Have a friend call you to see if you are recieving anything. If you recieve a call, the phone is running.
The screen may be malfunctioning
If the screen does not turn on, it may have problems and might need to be repaired or replaced.
The cell phone won't turn on
Battery may not be installed
Check to see if your phone has a battery.
Battery has no charge
If it does have a battery, the battery does not have power and needs to be charged. If the phone still won't turn on after charging, you may need to replace the battery
The keypad does not work correctly
Short in the wiring
There may be a short in the internal wiring.
Moist Environments
If your phone has been in extremely moist environments, you may need to open it up and let it dry.
The outer casing is broken
Physical Damage
Your casing may need to be replaced, depending on the damage.
The camera does not turn on or fails to work
Broken wire or loose connection
There may be a broken wire or loose connection inside your phone. You may need to check and see if your camera's connection is secure.
Faulty Camera
You may also need to replace the camera.
aaron gao
crwdns2935283:001/05/10crwdne2935283:0
107 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
Cal Poly, Team 11-4, Forte Winter 2010 crwdns2935289:0Cal Poly, Team 11-4, Forte Winter 2010crwdne2935289:0
CPSU-FORTE-W10S11G4
crwdns2935297:096crwdne2935297:0
out box messaging wont send
pam - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 3,077
