crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Device Won't Turn On
The power button is pressed and the device does not make any indication of activating.
Phone Needs to be Charged
If the device does not turn on, then the battery may need to be charged.
Dead Battery
If the device does not turn on then a new battery should be installed in the device. Replace with a new battery.
Bad Motherboard
If the device does not turn on then the motherboard may be faulty and may have to be replaced. Replace with a new motherboard.
Drained Battery
If the device does not turn on after being charged, then the battery may be defective and will no longer hold a charge. Replace with a new battery.
Device Won’t Charge
The device does not show any indication of being charged
Drained Battery
The battery may be defective and no longer be able to hold a charge. Replace with a new battery.
Loose Connections
Check to see if the charger is plugged into the power outlet. If it is and the phone is not charging, the charger may be defective or the wall outlet may be defective. Try to using another charger or plugging the charger into a different power outlet.
Phone Turns Itself Off
The phone deactivates itself on its own.
Screen Timed Out
Press the power button. It is possible that the phone screen is just timed out and the screen has turned black to conserve battery power.
Faulty Motherboard
The motherboard may be faulty. Replace with a new motherboard.
Screen Won’t Turn On
The screen on the device is not on even when the device is active.
Be Sure to Push Correct Button
On the Motorola Photon 4G there are two ways to wake the screen up. You must push the power button located on the top right corner of the phone or open the kickstand which will enable landscape mode and wake up the screen.
Broken Screen
If the screen on the device is cracked then a new one will need to be installed. Replace with a new screen.
If the screen on the device will not turn on then a new one will need to be installed.
Faulty Connections to LCD
If the screen is not responding, the electrical connections between the LCD and motherboard may be at fault. To access the connections, you will need to open the phone as if you are replacing a cracked screen. If the connections are found to be faulty, soldering may be required to re-establish electrical flow. Replace with a new screen.
Faulty Motherboard
The motherboard may be dysfunctional. Replace with a new motherboard.
Drained Battery
Your battery may have died. If the phone does not work when the battery is fully charged or when the phone is plugged in, it may be necessary to replace the battery. Replace with a new battery.
Buttons Won't Work
Pressing the buttons does nothing.
Buttons Not Fully Pressed
Make sure that you are pressing the buttons down completely.
Bad Connections
The key may not be making contact with the motherboard. Replace with a new motherboard.
Can’t Hear Anything When Placing a Call
When making a call you cannot hear the person on the other line.
Earpiece Broken
If you cannot hear the other line when making a call then the earpiece may be faulty. The earpiece should be checked and possibly replaced. Replace with a new earpiece.
Speaker Doesn't Work
If the speaker is not performing properly when putting the call on speaker then a new one must be installed. Replace with a new speaker.
Possible Water Damage
If sound is muffled or distorted, water damage may be the problem. If phone was in contact with water, allow to dry before taking more drastic replacement measures. If it still doesn't work after drying, then replace with a new speaker.
Distorted/Buzzing Sound From Speaker
The speaker of the device is making a distorted sound when placing calls.
Speaker Doesn’t Work
If the speaker is not performing properly then a new one must be installed. Replace with a new speaker.
Headphones Don't Work In Phone
"The audio cannot be heard through using headphones in the headphone jack."
Faulty Headphones
The headphones may be defective and audio cannot be heard from them. Try to use a different pair of headphones.
Faulty Headphone Jack
If the headphones are not faulty, check to see if any of the phone applications that play audio are active. If audio is supposed to be heard from the applications but is not, then the headphone jack may be faulty. Replace with a new Headphone Jack.
Jennifer Osterman
crwdns2935283:010/07/14crwdne2935283:0
153 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 8-6, Leahy Fall 2014 crwdns2935289:0USF Tampa, Team 8-6, Leahy Fall 2014crwdne2935289:0
USFT-LEAHY-F14S8G6
My phone doesn't keep Bluetooth on ,shuts off after about a minute ,what can i do ?
eberhard kallweit - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 1,893
