crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
If you turn on your phone, and the touch screen does not respond use this troubleshooting guide to help diagnose why.
Software Glitches
A minor software bug, a misbehaving third-party app, or a system update issue can cause the screen to freeze or act erratically. A common solution to this problem is to press and hold the power button for 10-20 seconds until the phone powers off. Press and hold the power button again to turn the phone back on.
Overheating
If the phone gets too hot from intensive use or being in direct sunlight, it can affect the screen's performance and cause it to become unresponsive. You should avoid any direct sunlight and remove the case to let your phone cool down.
Moisture or Debris
Water, dirt, and oil on the screen can cause the touch function to trigger ghost touches. You will power off the device and let it air dry in a well-ventilated area. Then, with the phone still off, use a soft-bristled brush (like a toothbrush) or a cotton swab to gently dislodge any visible debris from the USB-C port.
System Memory Overload
If too many apps are running at once, the phone's CPU (processing power) can become overwhelmed, leading to a frozen or unresponsive screen.
Follow the steps below to easily fix this issue:
  1. Connect your Edge Plus to another device like a laptop, with a USB cable
  2. Check the USB settings on the device connected to your phone to ensure files can be transferred
  3. If you encounter software issues, use the Software Fix tool to reflash your software
  4. If you choose not to use a USB cable, connect your phone via Wi-Fi using third-party software like MyPhoneExplorer
  5. If the steps above fail to fix the issue, try restoring the data on your phone using MyPhoneExplorer
Physical Damage
Dropping the phone can damage the internal components of the display, even if the glass is not visibly cracked. Review these instructions on how to replace the screen.
Ilan Neiman
crwdns2935283:009/10/25crwdne2935283:0
309 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 7-4, Kilpatrick Fall 2025 crwdns2935289:0University of North Texas, Team 7-4, Kilpatrick Fall 2025crwdne2935289:0
UNT-KILPATRICK-F25S7G4
crwdns2942667:0crwdne2942667:0 359
