Before trying to troubleshoot your Motorola C139's problems, try resetting the phone by turning it off and back on or by removing the battery.
Phone won't turn on
No matter what you do, you can't get your phone to turn on.
Charge the battery
Make sure the battery in the phone is fully charged. Plug the power chord into the phone and a power outlet.
Hold power button
Hold the red power button for about 5 seconds. If this does not turn the phone on the problem may be with a loose or bad battery.
Take the battery out
Remove the battery from the back of the phone and wait 30 to 60 seconds. Put the battery back into the phone and see if the phone will now turn on.
Replace the battery
It may be necessary to purchase a replacement battery. Look at the battery guide for help removing the old battery and installing a new battery.
Calls are not connecting
The phone is unable to call anyone.
Check Signal
The phone may not be receiving a signal. Check the signal icon to see if you are connected to the network. If you have no signal, relocate to a new location.
Replace Sim Card
The Sim card may be missing or was damaged. The Sim card may need to be replaced.
Replace Antenna
The antenna may be damaged and may need to be replaced.
Phone automatically turns off
When the phone is put into standby mode it turns itself off.
Charge Battery
The battery may have died. Plug the power chord into the phone and a power outlet and see if it will charge.
Change settings on the phone
Your phone's standby mode may be activating causing the phone to automatically turn off after a period of time has passed. To check whether this is the case, check the settings menu on the phone to see if standby mode is activated.
Battery not charging
If your phone's battery is not charging there may be one of several reasons for this issue.
  1. Weak battery
  2. Broken power adapter
  3. Faulty electronics
Replace Battery
After identifying the battery is at fault the main course of action is to replace it. Please consult how to remove your battery.
Replace Charging Cord
The charging cord may be broken and need to be replaced.
Phone is not vibrating
The phone no longer vibrates or has a weak vibration
Replace Vibration mechanism
If you have noticed that your phone no longer vibrates the vibration mechanism may be broken and needs to be replaced. Follow the guide to replace the vibration mechanism.
Speaker Broken
No sound is coming from the phone.
Replace Speaker
Your phone's speaker may be faulty. Following the steps in the guide to replace the speaker.
Sticky Keypad
The keypad is sticky due to a spill or for another reason.
Wipe Keypad
Before taking the phone apart. This problem might possibly be fixed by lightly wetting a cloth and wiping the keypad gently.
Replace Keypad
The keypad may need to be replaced or taken out for more intensive cleaning. See the guide for replacing the keypad.
Cracked Casing
The phone was dropped and now the phone casing is cracked.
Replace Casing
The phone casing will have to be replaced with a new one. To detach the casing from the actual phone, follow this guide for the front casing and this guide for the back casing.
Kyle Olbrich
crwdns2935283:003/09/12crwdne2935283:0
33 crwdns2915208:0crwdne2915208:0
Clemson, Team 2-2, Benson Spring 2012 crwdns2935289:0Clemson, Team 2-2, Benson Spring 2012crwdne2935289:0
CLEM-BENSON-S12S2G2
crwdns2935297:096crwdne2935297:0
crwdns2942667:0crwdne2942667:0 2,479
