crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Speaker has no power
No matter what you do, you can't get your speaker to turn on.
Power switch is turned off
Before going in depth into your speaker, make sure the power switch is in the “on” position.
Drained battery
If your speaker will not turn on, there is a chance the battery is drained. The speaker must be hooked up to power using the USB charging cable.
USB charging cable is incompatible
If your USB charging cable will not fit into the charging port, make sure you have grabbed the correct charger that was provided with the speaker. Having an incompatible charger will not supply power to the device, thus causing the speaker to not turn on.
No sound or low volume in Bluetooth mode
You cannot hear any sound coming out of the speaker when a Bluetooth connection has been made.
Volume check
Be sure to determine that the volume is up by pressing the + volume button.
Volume on paired device is not on silent mode
Check the volume on the device you have connected with Bluetooth to be sure the sound is adjusted. The two devices tend to have independent volume levels.
Make sure the speaker is leveled
Keep the speaker upright. The speaker has a feature that if it is turned upside down, the sound will not play.
No sound or low volume in AUX IN mode
You cannot hear any sound coming out of the speaker when an AUX IN cord is connected.
Volume check
Firm connection between both devices
Double check to make sure the cord is firmly secured on both devices.
Disconnect from Bluetooth devices
Disconnect from all Bluetooth devices as it will interfere with the AUX IN connection.
Bluetooth speaker and device keep unpairing
My device keeps unpairing.
Disconnect and re-connect
Unpair both devices from each other to lose connections, and then re-pair devices to each other.
Range of devices
Have both devices closer to each other in range so the connection will be stronger.
Drained battery
Be sure that both devices are charged or connected to a power source for stronger Bluetooth connection.
No Bluetooth Connection Can Be Established
When trying to connect a device via Bluetooth, it doesn’t connect to the speaker.
Confirming your device supports Bluetooth connections
Make sure your phone or other device has the ability to connect to the speaker through Bluetooth. You can find out by going to the settings app from your device.
Dead battery
If you cannot get it to connect to Bluetooth, make sure the speaker is charged. Does the LED turn on when you switch the device to ON? If not, use the provided USB cord to charge the speaker.
Not in pairing mode
Set the speaker to pairing mode. To do this press the button until the LED blinks red and white. Then make sure your Bluetooth device is also in paring mode, this can be found through the settings app in your Bluetooth device.
Device not in range
The Modal MD-SPBT01 has a range of 33 feet. Make sure the device you wish to connect is in the proper range.
Nathan Hall
crwdns2935283:010/13/15crwdne2935283:0
258 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team 2-4, Blackburne Fall 2015 crwdns2935289:0Sam Houston State, Team 2-4, Blackburne Fall 2015crwdne2935289:0
SHSU-BLACKBURNE-F15S2G4
crwdns2935297:048crwdne2935297:0
crwdns2936753:030crwdne2936753:0 41
crwdns2959996:0crwdne2959996:0 1,920
