The convenience of a portable device is that you aren't tethered to an outlet. This does mean that you have to give your device some juice once in a while. But if you can't get it to take a charge, it's no different than any wired device. Don't settle for a corded tablet.
First Steps
Before undertaking any of the more time-consuming solutions below, here are a few fundamentals to get you started.
  • Check the light on the charger. If there is no light, flip the charger 180 degrees. It may work in one direction, but not the other. Skip through to Faulty Power Source if you have no light.
  • Force a restart. This may clear minor system errors. Be sure to use the proper procedure for your model.
    • For the Surface Pro 5 and newer, plus all models of Surface Go, press and hold Power for 20 seconds to force a shutdown and subsequent boot.
    • On the Surface Pro 4 and earlier, press and hold Volume Up and Power for about 15 seconds. Wait a few seconds, then power on again as usual.
  • Remove all accessories and peripherals. They can interfere with the charger. making proper contact.
  • Is your battery detected by Windows? If no, remove the charger when your Surface is on. Does it stay on without the charger connected? Immediate shutdown points to a battery issue.
Faulty Power Source
Surface devices have long featured a proprietary charger type. It's conveniently compatible with most Surfaces—even the Surface Book and Surface laptop use it.
  • Check the light on the charger. It should be lit when connected to the device. If it is not, try a different charger.
  • Use an Authentic Microsoft charger if possible. Third party chargers for Microsoft devices are notoriously troublesome.
  • Verify the outlet the charger is plugged into is providing power. Connect a known good device and see if it powers on.
  • If your Surface has a USB C port, try to use that to charge. Be sure the wattage of your charger is at least equal to the original charger.
Faulty Charge Port
Like all mobile devices, the charge port is especially susceptible to damage and wear. It more exposed than the rest of the tablet's circuitry. Crevices in a device will always attract things you don't want them to.
  • Verify the port is clean. Does a charger sit flush against the edge of the shell? The port may be clogged if it sits at an angle or has a loose fit. Use a flashlight to inspect.
    • Remove anything caught in the port. Use compressed air and a toothpick to avoid damage. Other non-conductive tools can be used in place of a toothpick, but avoid inserting anything metal.
    • Isopropyl alcohol and a cotton swab can be used to get rid of persistent grime.
    • Once the debris has been removed, give charging another go.
  • Check for signs of damage or burn. A bad charger can also damage the port, or the board.
  • Pay attention to charging light behavior. The light will come on when the Surface recognizes it is connected.
Aging Battery
Batteries are nefarious. They fail often, due to their "consumable" nature, but not always in predictable ways. Although they typically die slowly and with diminishing power on time, a bunk battery could fail suddenly, or may not be recognized by the system.
  • Check for visual signs of battery swelling. This may manifest as areas of discoloration on the display (swelling exerts pressure on the display from the inside). The display may also bow outward, or separate from the housing.
  • Internal signs of battery age or failure could include leaking or lumpy battery cells.
Motherboard Fault
The motherboard is the hub for most of a Surface’s functionality. Any of the small components on the board may have failed or become damaged. Motherboard fault is a safe assumption of cause if nothing else on this page has worked.
Firmware bug
For the Microsoft Surface 2 (model 1572), UEFI releases before v4.22.500 (released in October 2014) have a bug where the battery can drain to 0% and then is unable to charge:
You can check which UEFI firmware your Surface 2 has by running the following in cmd:
wmic bios get biosversion
A possible solution is to open Device Manager and Uninstall the "Microsoft ACPI-Compliant Control Method Battery" under Battery and then remove the charger, powering off the device. Repeat this until the battery begins charging, or you lose patience.
Additional Information
Alisha C
crwdns2935283:012/04/20crwdne2935283:0
43.515 crwdns2915208:0crwdne2915208:0
LGBTQ Technicians crwdns2935289:0LGBTQ Technicianscrwdne2935289:0
Community
crwdns2931471:069crwdne2931471:0
crwdns2935297:0850crwdne2935297:0
翻译得太好了,简直完美!
超级大粘痰 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 102
crwdns2936753:030crwdne2936753:0 397
crwdns2942667:0crwdne2942667:0 13,983
