crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
NutriBullet Will Not Turn On
The blender will not respond and does not show any signs of powering up.
The blender is not plugged into a wall source
Check to make sure the cord is properly plugged into the wall outlet. The wall outlet must provide a minimum of 120 volts. Any voltage less than 120 volts will not turn the NutriBullet on.
The blender has a faulty cord
Inspect to see if the cord is torn or wire is exposed. If it is, then follow these guidelines to replace the cord.
The cup is missing a tab
Check the cup you're using to see if a tab has broken off. If it has, the blender will not power up.
Electrical Problems
If the Bullet has been subject to extended, non-pulsed use, two electrical components could have failed which would cause the Bullet to not spin. In either case, at the time of failure there probably was a smell of hot metal or electrical components. The two components are: a heat sensor which fails permanently if the motor coils heat above 105deg Celsius; or the carbon brushes which conduct electricity to the commutator segment of the motor. Diagnosis will require a disassembly of the unit, and require an electric multimeter as a tool to assess conductivity.
NutriBullet Leaks
The device is blending food, but there are evident leaks and spillage.
Extractor blade is not screwed onto the cup lid tightly
Check to see that the extractor blade is screwed onto the cup lid properly by using the ridges on the cup as a guide. If it still does not screw on properly, order a new one here.
Rubber seal on extractor blade is torn or ripped
There is a rubber seal called the gasket on the underside of the extractor blade. This helps to secure it to the cup and prevent leakage. If it is torn or ripped, follow this guide to replace it.
Cup is not properly secured into the powerbase
Ensure the cup is tightly secured and locked into the high-torque power base. There are three slits on the powerbase that match the three lips located on the side of the cup.
There are cracks on the interior or exterior parts of NutriBullet
Detach the cup from the high-torque power base and inspect all parts of NutriBullet powerbase to ensure no cracks are found. If there is a crack, the NutriBullet could expose wires or fast moving components. If a crack is found on the base, replace it. If a crack is found on the cup or lid, '''purchase a new one.'''
Blades Do Not Turn
Although the device is plugged in and on, the blades refuse to turn.
The blender has been in use for a prolong period of time
The makers of the NutriBullet recommend that you do NOT blend for more than 1 minute. Prolonged use of the machine can cause the motors to wear out quickly, which can affect the blades.
Motor refuses to turn even though cord is plugged into a wall source
If the blades do not turn and you notice a burning smell, unplug the power base and let it cool for an hour. The powerbase will reset once the unit is unplugged.
Activators refuse to operate even though cup is tightly secured to the powerbase
In order for the NutriBullet to blend, there are special white activators on the top of the power base which begins the blending process. If the blades fail to turn when the cup is in the powerbase, the activators could be stuck. Follow these instructions to replace the activators.
Blades Refuses to Cut or Blend Food
The blades will not blend food items fully or takes a long time to do so.
There is food stuck in between the blades
First, unplug the NutriBullet from the outlet and remove the extractor blade to clear any obstruction or build up of food. Be careful not to cut or injure yourself in the process.
The cup is too full to blend or cut food
Depending on which cup you are using (30 oz Short Cup or 45 oz Oversized Cup), there is a max line which determines how much food or liquid is recommended. Surpassing the max line could prevent the blades from cutting or blending food.
The blades are spinning, but refuses to blend or cut food to its entirety
Blades may be dull and new replacement blades can be ordered here.
Blender Stops Suddenly During Use
When you are using the NutriBullet, the machine stops suddenly during use.
Blender becomes unplugged during use
Ensure that the cord is still plugged in the wall and has not come out during its use.
The blender has wires and other components exposed
Loose wires and other internal components from the device may become exposed during the course of use. If so, please refer to the replacement guide on how to replace the outside casing, which makes it easier to work on internal parts of the device.
Geary Yu
crwdns2935283:001/22/15crwdne2935283:0
1,295 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 19-8, Maness Winter 2015 crwdns2935289:0Cal Poly, Team 19-8, Maness Winter 2015crwdne2935289:0
CPSU-MANESS-W15S19G8
crwdns2944067:0143crwdne2944067:0
I would like to point out there is a flaw concerning the base attachment. The flaw being the direction the base rotates in will cause the cup to become loose. This in turn causes the unit to leak. Refitting with left hand threaded cups and blade assemblies would alleviate this problem.
henrysisson - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have just purchased a 900W machine and it leaks like a sieve!! there is nothing broken or torn the cup just seams to come undone whilst the machine is running, this is hopeless
Helen - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
This happened to me as well. I ordered a replacement jar after a tab broke off the original and it would no longer operate. The replacement was garbage. The base would not easily seat on the new jar but after carefully screwing it on, I thought I had it covered. Nope. I turned it on and the d##m thing loosened and there was a flood of smoothie everywhere. The flood ruined the motor - this was as I said - a flood. Now I have a drawer full of cups and blades with no base. Should I discard them all and look for something else?
jhjones713 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have this same issue and came here to find an answer. It didn’t do it originally, but now every time I try to use it, it loosens and risks a leak. I daren’t use it anymore. It’s a shame because it was a great blender before this started. Also, it does it with both attachments even though one is barely used, and the cup is fine, so it must be the actual unit that is the problem somehow.
Lottie Bennett - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My Nutribullet cup with blades attached will not drop down into the blending mechanism. It stops about an inch above, so doesn't get close the the white activator switches. What is it hitting? How can I fix this?
astarrfire - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 105
crwdns2936753:030crwdne2936753:0 499
crwdns2959996:0crwdne2959996:0 347,612
