crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Short lasting battery life
Tablet won't stay on as long as it's suppose to.
Faulty Battery
If your tablet doesn't sustain a long battery life when fully charged, then you should consider buying a replacement battery. You can use our guide here as an example to properly explain how to replace the battery yourself.
Faulty Power Adapter
There is a possibility that the adapter is not fully charging the device properly. In that case make sure there is power to the outlet that it is plugged into. If there is, make sure the power adapter is functional, by making sure your battery charges up to its max capacity. If it doesn't, your power adapter is faulty and you should consider getting a replacement.
Screen becomes unresponsive
Screen fails to respond or function properly
Internal glitch
When the screen gets stuck on a specific page, this could simply be an internal glitch with the device and may need to reboot, or be completely reset.
Screen bubbles
If an air bubble forms, and doesn't disappear over time, causing the screen to malfunction, you may need to use our screen replacement guide here to fix this issue.
Faulty screen
When the screen becomes completely unresponsive to user commands, there is likely an issue with the screen board. With such issue, a screen replacement is necessary. Click here
Device won't power on or unlock
User becomes unable to utilize the tablet, due to the power button becoming unresponsive
Power button is stuck in the device
The power button may be jammed in the device. If this issue persists, replacement of the power button may be necessary.
Device is incapable of downloading applications
"User is unable to download applications from the Play Store"
Settings Issues
If the device is unable to download applications from the Play Store, then click here to see a list of troubleshooting steps from Google Play's website that may be needed to restore Play Store function:
Http://www.ifixit.com/Device/Mid_7006
Http://www.ifixit.com/Wiki/Mid_7006_Troubleshooting
Raul Oviedo
crwdns2935283:010/11/16crwdne2935283:0
22 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
Texas Tech, Team 38-1, Bennett Fall 2016 crwdns2935289:0Texas Tech, Team 38-1, Bennett Fall 2016crwdne2935289:0
TTU-BENNETT-F16S38G1
crwdns2959996:0crwdne2959996:0 419
