crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
No Sound from Speaker
There is no sound coming from the speakers.
No Device Connected
Make sure a device is connected to the speaker. Use a AUX cable to eliminate the possibility of a blue-tooth problem
Low/No Power
The Logitech UE Boombox uses a rechargeable battery. Be sure that the battery is not out of charge and the Boombox can still operate. We recommend leaving the Boombox plugged in for 30 minutes before trying again.
Broken Speakers
A sign that there is a broken speaker in the Boombox is a slight humming or buzzing noise. The sound maybe very subtle, so it is advised to turn the volume higher in order to increase what little noise the speakers make.
Audio Player Not Working Properly
Your audio player may not be working properly. Use another speaker device to confirm your audio player is working properly. If the audio player still does not work, consider replacing your audio player.
Device Will Not Turn On
My device will not turn on.
Low/No Power
Power Button Stuck In Place
If the power switch does not move, the button may be stuck in place. You may need to wipe the area under and around the switch to make sure nothing is preventing it from moving. After the button is sufficiently cleaned, try moving it into position once again.
Bluetooth Pairing Is Not Working with My Device
I tried connecting my device to the Logitech UE Boombox but audio is not playing.
Check Device Bluetooth activity
Assure that Bluetooth pairing is enabled on your device that is connecting to the speaker. Scan for devices on Bluetooth menu and select UE Boombox. Once paired and connected an audible confirmation will be heard from the speaker.
Check UE Boombox Pairing
Turn on speaker by sliding the power switch on the left upward. Bluetooth connection is ready when LED around the Bluetooth button blinks rapidly. Additional devices can be added by holding down the Bluetooth button on the left side of your Boombox until you hear a tone and LED around the Bluetooth button will indicate pairing is ready.
Range Between Device and Speaker
Place your Bluetooth device closer to the Logitech UE Boombox because the distance between the two can affect pairing if device is not in range of the speaker.
Interference from Wireless Sources
Interference from other wireless sources can affect pairing between Bluetooth device and Logitech UE Boombox. Move both away from wireless sources.
Too Many Devices Connected
Logitech UE Boombox can have up to eight devices paired with it, but connection can only be maintained by three at a time. If three connections are already active, a fourth connection cannot be added. Remove one or more connected devices by disconnecting Bluetooth pairing and connect new device.
Distorted Sound from Boombox
I am hearing double-echoes and distorted sounds from the speaker.
Place your Bluetooth device closer to the Logitech UE Boombox because the distance between the two can affect sound distortion if device is not in range of the speaker.
Interference from other wireless sources can affect sound distortion between Bluetooth device and Logitech UE Boombox. Move both away from wireless sources.
Steaming Audio Content from Internet
Try checking the internet connection. Poor connection can lead to audio distortion.
Calls Are Double-Echoing
Try adjusting the speaker volume on Logitech UE Boombox. Usually, this is a feedback issue between your speaker and Bluetooth. It does not indicate a damaged speaker.
tyler hua
crwdns2935283:009/15/16crwdne2935283:0
304 crwdns2915208:0crwdne2915208:0
CSU Fullerton, Team 1-1, Bruce Fall 2016 crwdns2935289:0CSU Fullerton, Team 1-1, Bruce Fall 2016crwdne2935289:0
CSUF-BRUCE-F16S1G1
Mine won't take a charge it's starts to charge meaning white charging light flashes as normal but only for a few seconds?
Renee Smith - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2942667:0crwdne2942667:0 2,188
