crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
If you are having issues with unresponsive keys when attempting to type with your Logitech K360 keyboard, follow this page for solutions.
Mechanical Wear
How can you identify Mechanical Failure?
The keys don't register when pressing it or inconsistency.
As well if it feels loose or "soft", the swift underneath the keycap may be worn out or damaged.
If none of your keyboard's keys work, it is usually a mechanical failure. If this is just specific keycaps, then you can fix those specific keys.
Debris Stuck under Keys
How can you clean your keyboard?
If specific keys feel sticky or you see visible particles under keys, it is caused by debris. You can remove the keycaps by taking apart your keyboard. Then use compressed air or simply clean it with a soft towel to get the gunk out.
Lost the Original Receiver
How can you connect a fresh receiver to the Logitech K360?
First, you want to visit the Logitech Unifying Software link and download the software. (Logitech-Unifying-Software ) Dongle replacement tutorial
Plug your receiver into the laptop/computer.
Make sure the K360 is turned on.
Using the software you are able to connect the dongle to your keyboard within 2 minutes.
After it’s done connecting, verify by typing a sentence.
Now press Finish.
Your keyboard is now connected to its new receiver!
Dead or Weak Batteries
Battery life is incredibly important for a good performance from the keyboard. A weaker battery power may weaken your keyboard's signal.
You can check on the top right of the keyboard. Check if the light is on. If not, you most likely need to replace the batteries. To replace the batteries, flip the keyboard so that the keycaps face downwards. On the back, there should be a compartment that you can remove to replace the batteries. The keyboard uses two AA batteries.
Interference
When looking for signs of interference, look for:
Test for the source of interference by moving the keyboard to a different environment. Be careful with crowded workspaces, as metallic objects can obstruct signal transmissions.
Then, predict the source of interference. If you assume it's an electronic that’s also producing radio frequencies.
Now try to move the setup away from those devices.
Most non-Bluetooth wireless keyboards operate at 2.4 GHz. So, other electronic equipment such as microwaves or blue-tooth devices working at that specific frequency can create interruptions, which lead to performance and connectivity issues for the wireless keyboard.
Othon Sanchez
crwdns2935283:002/20/25crwdne2935283:0
349 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 7-3, Kershman Spring 2025 crwdns2935289:0CSU Los Angeles, Team 7-3, Kershman Spring 2025crwdne2935289:0
CSULA-KERSHMAN-S25S7G3
crwdns2936753:07crwdne2936753:0 31
crwdns2936753:030crwdne2936753:0 88
crwdns2959996:0crwdne2959996:0 1,347
