crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Are your Logitech G X56 HOTAS Joystick buttons unresponsive when pressed or used? Use this troubleshooting guide to help diagnose why.
Bad Physical Connections
Over time, USB cords and ports can stop working due to physical damage or debris buildup, preventing a secure connection to your Joystick. Examine the ports and cables from physical damage and replace cable ports. Ensure all USB cables are securely plugged into your PC to rule out connection issues preventing button responses.
Joystick Needs Calibration
The Joystick can lose its precise calibration through shipping, prolonged usage, and temperature changes. To recalibrate the Joystick:
  • Press Win + R, type joy.cpl, and press Enter.
  • Select Logitech G X56 HOTAS from the list, then click Properties.
  • The Test tab will automatically open. Select the Calibration button from there and follow the on-screen instructions to recalibrate the Joystick.
Buildup Obstructing Button Response
Buildup from dirt, dust, or liquid spills can cause buttons to become stuck or unresponsive. To clean:
  • Turn off and unplug the Joystick.
  • Use a can of compressed air to blow out dust and debris around the buttons.
  • Dampen a Q-tip or microfiber cloth with isopropyl alcohol and gently clean the button surfaces and gaps.
  • Use a soft brush to ensure the device does not get scratched and to remove any remaining dirt from the crevices.
  • Let the Joystick dry thoroughly before plugging it back in and turning it on.
System Errors
Connect the Joystick to a different PC to determine if the issue is hardware-related. If the Joystick responds to a different PC, the problem may be with your current PC's settings or software.
Outdated Logitech Software & Drivers
Outdated drivers or Logitech G HUB/X56 software can cause conflicts and prevent buttons from responding correctly. Visit Logitech's official website to download the latest updates for the X56 HOTAS and ensure Logitech G HUB or X56 software is current.
Faulty Buttons
Some buttons on the joystick may be damaged due to overuse, so replacing the buttons may be the best option.
Abhiram Dintakurthi
crwdns2935283:002/19/25crwdne2935283:0
221 crwdns2915208:0crwdne2915208:0
University of Memphis, Team 1-5, Sneed Spring 2025 crwdns2935289:0University of Memphis, Team 1-5, Sneed Spring 2025crwdne2935289:0
UM-SNEED-S25S1G5
crwdns2936753:07crwdne2936753:0 31
crwdns2936753:030crwdne2936753:0 105
crwdns2959996:0crwdne2959996:0 928
