crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Keyboard Not Lighting Up
My keyboard isn't lighting up.
In result of a non-proper setting of the keyboard lights, the lights may stay OFF. First, check the setting and make sure your light option is ON. If it's ON, then you need to reconnect the cord to the computer. Also, you can test the keyboard with another computer.
Buttons are not pushing
The keyboard buttons are stuck.
In result of spilled drinks, keys get stuck and refuse to push. You can try to put it back on the keyboard, making sure nothing is stuck below. Then, try to push it gently until you hear a click. Make sure that you put the key in the correct direction to avoid breaking the board.
Background color not displaying
Color is not showing up.
The “broken” background color consist in, when you are using the keyboard there is no color by the frame, or it is not the color of your preference. The board flash memory is responsible for that, and most of the time it lacks the setting of colors. So when you log out, the colors that you were using got stuck and wouldn’t upload. There is two common ways to troubleshoot that. One of them is to activate lighting, and the second one is to customize lighting setting in Logitech G910 Software.
Open Logitech Gaming Software and click on the light bulb icon, click the commands lighting mode icon. Under the Options tab, click Set Command Colors. The Commands list will appear on your left. Select the colors you want.
Shadi Alzanbagi
crwdns2935283:001/16/18crwdne2935283:0
460 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team S2-G2, Munoz Winter 2018 crwdns2935289:0Eastern Washington University, Team S2-G2, Munoz Winter 2018crwdne2935289:0
EWU-MUNOZ-W18S2G2
crwdns2935297:048crwdne2935297:0
crwdns2944067:023crwdne2944067:0
i bought this key board less then a year so 6 months or slightly more and the U key and now the I key are not holding color they are turning puke green when they suppose to be blue.
jay biggumz - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
that is the blue part of the rgb led being dead, red and green will still work but anything with blue is a no show.
Josh Smyth - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
The app won’t work, it’s not loading, so I don’t have colour or light on my keyboard.
Lan Hamilton - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I can’t help but notice the macro keys have stopped working in Revit 2020 by Autodesk. It works on previous version which helps speed up the model and design production process. The lights also do not switch to the new profile like in the previous versions of Revit as well. This leads me to believe that Logitech may have changed the way the keyboard input works for the software because it works with the previous versions. I doubt Autodesk has changed the software to cause this issue or it would have appeared earlier. For many people developing the 3-D, VR and AR environments for the games people play, movies people watch and the buildings/homes people have built can you please look into this for the affected professionals like myself? Thank you.
Cadwerks.Studios - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I didn’t like G Hub when it first came out and I like it even less now. My keyboard will not light up and the keys that I had bound are no longer bound. This is a total mess
Debra Boinay - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 82
crwdns2942667:0crwdne2942667:0 44,764
