crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
If the screen is frozen on your Little Tikes Tobi 2 Interactive Karaoke Machine, follow this troubleshooting page for helpful tips.
Loose Connection in LED Cables Causing a Disruption in Power to Lights
Use a screwdriver to open the machine and observe its internals. Cut the problematic section out and replace it using solderless connectors. Alternatively, if the wires are still intact, you can attempt to readjust them and tape them down so they won't dislodge again.
Dead Pixels
With the device off, remove the front plate and apply pressure to the stuck pixel using an object like a stylus or the eraser end of a pencil with a soft cloth protecting the screen. While applying pressure, turn the device back on, then remove the pressure.
Infected with Malware
The device may have been connected to malicious software through Bluetooth. The hard drive will need to be replaced. Alternatively, you can insert the hard drive into a compatible personal computer and perform a scan using the check disk tool, CHKDSK command, or file repair software such as Hetman.
Damaged Screen
If the screen is damaged on your Little Tikes Tobi 2 Interactive Karaoke Machine, follow this screen replacement guide to replace it.
Board Failure
If your screen is not damaged but you suspect the damage is the circuit board, use this guide to replace it.
Isaiah Eagle
crwdns2935283:009/04/24crwdne2935283:0
607 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 5-4, Kershman Fall 2024 crwdns2935289:0CSU Los Angeles, Team 5-4, Kershman Fall 2024crwdne2935289:0
CSULA-KERSHMAN-F24S5G4
crwdns2942667:0crwdne2942667:0 239
