crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Printer Won’t Turn On
Bad battery
If the printer won’t turn on at all, a dead battery is more than likely the cause. Follow our guide on testing and replacing the battery.
Bad charge port
The charge port or cord may be broken if the printer does not charge or does not power on completely. Ensure the charger works by using it with another device.
Dead motherboard
If the printer doesn’t turn on or is malfunctioning, the motherboard might be damaged or broken. In this case the device is truly dead, and replacement of the entire device is needed.
Printer Unable to Read Paper
No paper
There is no paper in the tray. Make sure Zink photo paper is in the appropriate compartment and fully in place. Then try printing again.
Paper inserted incorrectly
Make sure all photo paper in the tray is the same type and size. Never load several types of mixed paper and make sure to properly align the edges of the photo paper.
Broken paper sensor
Clean the photo paper sensor with a lint-free cloth. If the problem persists, use the following guide.
Paper Stuck in Printer
The special paper to make the photos, could get stuck and mess up the photo.
Broken roller
If the roller seems not to be working, you would want to clean the roller with a lint-free cloth.  Make sure that the roller is able to turn free and correctly.
Incorrect paper
When refilling your printer, make sure that you are using the specific LifePrint 2x3 printing paper.   The correct paper is LifePrint 2x3 Zero Ink sticky backed film.
Creased paper
When refilling your printer, make sure that the paper doesn’t have any damages or bends to it.  If the paper does, then you will need to use a new piece of file
Printer Unable to Connect to Bluetooth
Bluetooth antenna broken
If the Bluetooth antenna appears to be broken (at an odd angle or completely broken off), please follow the guide on repairing the Bluetooth antenna.
Phone Bluetooth not on
If the device is not connecting via Bluetooth to your phone, make sure Bluetooth is turned on in your phone setting.
Not up to date
If there are persistent error in the connection from the LifePrint 2x3 Printer and your phone, please be sure to see if your printer is up to date and is compatible with your phone.
Distorted Pictures
Printer head misaligned
If pictures are coming out distorted, or the paper is printing creased, be sure to check the printer head that is aligned properly within the device.
Debris inside printer
If the images are printing out with dried debris and is distorting images, please be sure to open up the printer and clean printer with a dry cloth.
Paper contaminated
If the paper is printing out distorted or with various places of saturation or color inconsistency be sure that the paper, you are using has been stored in a dry climate and not exposed to too much light within the package.
Calli Brown
crwdns2935283:009/24/19crwdne2935283:0
172 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S15-G6, Lamothe Fall 2019 crwdns2935289:0Embry-Riddle Aeronautical University, Team S15-G6, Lamothe Fall 2019crwdne2935289:0
ERAU-LAMOTHE-F19S15G6
crwdns2935297:036crwdne2935297:0
crwdns2944067:019crwdne2944067:0
The queue on my lifeprint is not updating after it prints something. So every time you turn it on, another one of the same picture prints. If you try to print something else, it just gets added to the queue and it does not print. How can you fix this?
Alice Shah - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have the same problem, any help on this?
Karina Paredes - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
How do you delete pictures in queue?
Printer keeps printing the same picture. And I have to turn printer off and on to print another photo.
Joan Snapp - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Same issue here, although 3 years later. Any answers how to delete photos from the queue? I don’t want to print all that is in there.
Irene - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Slide the picture to left and a delete button shows up.
Hierophant Paranormal - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 47
crwdns2959996:0crwdne2959996:0 8,024
