crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Touch screen does not work
The tablet is unresponsive to any form of touch.
Faulty Screen Driver
When any form of touch does not register it could be that the driver needs an update, without the most up to date version it will not function. Open device manager and navigate to the Human Interface Devices option, then expand to find an HID-compliant touch screen or HID-compliant device. Right-click on either one and the option to update should appear to left-click on the update option.
Faulty Screen
Another possibility as to why you can not interact with the device screen is that it could just be a faulty screen. If even after updating the driver it could just be a faulty screen Replace the Screen with this guide.
Battery Plugged in, Not Charging
The device can not hold a charge past 100%
Faulty Power Driver
The driver is not allowing a 100% charge because the driver may need an update. All you need to do is uninstall the older version of the drive and install the Lenovo power management software's latest version. Open device manager and locate Batteries two options should be listed Right-click on the control method battery and left-click update.
Faulty battery/ ac adapter
If updating the driver does not help it could be the battery or possibly the ac adapter are just no longer functioning. First thing you must check whether the ac adapter can charge perhaps another of the same device. To determine this check the led light located right next to where you would plug in the adapter in your tablet. If not replace adapter which you can buy either online or in-store. If it works then you might have to replace the battery, if that is the case use this guide.
There is no sound
Sound is not available
Faulty Sound Driver
Without an up to date version of the drive, it will not function you may need to check the device driver to see whether or not it requires an update. Open device manager and look for audio inputs and outputs, from which when you find it you left-click the arrow next to it should see two options Microphone and Speakers. Right-Click on speakers you will be given different options click the update option.
Replace the speaker
If after the update the speakers still do not provide any sound, the only other solution is to replace the speakers. For instructions on how to replace the speaker use this guide.
Wireless does not connect
I cannot connect to the wifi.
Faulty driver
If you can’t seem to be able to connect to WiFI it could be that the driver needs an update. Open device manager and locate network adapters and left-click on the arrow next to it. From here you want to look for the Wireless Network Adapter, right-click on that option and you should be given a few options. Left-click on the update option which will check to see if it is already updated or needs one.
Replace the NIC
If an update does not fix the problem you may need to replace the NIC, which if that is the case use this guide.
The laptop seems a little slow
You are on your laptop and it just seems to take forever to do anything.
Upgrade Memory
Your RAM (Memory) is a factor that determines how quickly you can load apps or processes. If you want faster speeds you can upgrade the RAM, if that is the case use this guide . Upgrading your Lenovo Thinkpad Helix RAM will allow you to run your system more efficiently and increase your productivity.
Manuel Parra Rocha
crwdns2935283:008/26/19crwdne2935283:0
494 crwdns2915208:0crwdne2915208:0
Gateway, Team S1-G6, Saknee Fall 2019 crwdns2935289:0Gateway, Team S1-G6, Saknee Fall 2019crwdne2935289:0
GCC-SAKNEE-F19S1G6
crwdns2935297:036crwdne2935297:0
crwdns2936753:030crwdne2936753:0 53
crwdns2959996:0crwdne2959996:0 2,391
