crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Overheating is a common issue that can affect performance, cause damage, and shorten the lifespan of any device. This troubleshooting guide will help you identify the causes and provide step-by-step solutions to cool your device down and keep it running efficiently.
Poor airflow
Dust blockage in any air vents may be preventing air from flowing properly. Warmer air is typically blown out of the vents on your device, but if there’s a dust blockage, the warm air gets trapped inside.
Open the device. Scan the areas of ventilation. It should be easy to spot buildups of dust and debris. Use compressed air to blow out as much debris as possible. Remove and clean the fan separately for more efficient results.
Running Demanding Usage
The more demanding the tasks your device handles, the more heat it produces. A rise in temperature doesn’t necessarily mean your device is overheating or at risk. There are a few simple ways to check whether the heat levels are within a safe range.
  • Open Task Manager: Press Ctrl+Shift+Esc.
  • Click on the Processes tab.
  • Click on the CPU column to sort processes from highest to lowest CPU usage.
  • Identify and end processes that have a high usage of CPU. Click "End task".
  • Continue until CPU usage returns to normal levels.
Fan Failure
A lack of air movement can also occur when the fan inside isn’t working properly. Fan failure could be caused by dust blockage or a broken fan.
Listen to see if the fan is working correctly. If the fan is making a normal sound, showing signs of proper function. The fan should not be the problem. If the fan is making any clicking, breaking, or grinding sounds. You may want to replace the fan. Please refer to the Fan Replacement guide if you need to replace the fan
Software Corruption
Information is constantly being written, overwritten, accessed, or deleted. It can be challenging to manage data on your device. As your system's performance can be affected after an update or power loss. When software is corrupted, it forces the device to work harder. Generating more heat and causing hardware malfunctions that lead to overheating.
To scan for malware, update your computer software to the latest updates.
Run a full system scan to identify and remove potential malware:
  • Open Windows Security: (search for it in the Windows search bar)
  • Select "Virus & threat protection"
  • Choose "Scan options”
  • Select "Full scan" and then "Scan now"
  • Follow the on-screen instructions: scan to complete
Run System File Checker (SFC). This will scan for and repair corrupted system files. :
  • Open Command Prompt as an administrator.
  • Type sfc /scannow and press Enter.
Run CHKDSK (Check Disk). This will scan the hard drive for errors and attempt to repair them.
  • Type chkdsk /f /r and press Enter.
Run a system restore.
Navigate System Restore in Windows settings.
Select a restore point from before the issue began and follow the given instructions.
Alejandro Hernandez
crwdns2935283:004/09/25crwdne2935283:0
147 crwdns2915208:0crwdne2915208:0
Linn Benton Community College, Team 1-4, Karnes Spring 2025 crwdns2935289:0Linn Benton Community College, Team 1-4, Karnes Spring 2025crwdne2935289:0
LBCC-KARNES-S25S1G4
crwdns2942667:0crwdne2942667:0 434
