crwdns2862637:0crwdne2862637:0
crwdns2869081:0crwdne2869081:0
Lenovo IdeaPad 1-15IJL7 Audio Distortion
Audio does not display quality volume.
Incorrect Audio Settings
Excessive volume can result in overuse causing distortion. On another note, device may not be on correct audio output.
Solution: Select 'Advanced tab' audio format through 'Playback Services.'
Drivers Not Updated
Not having the latest audio drivers, for example, BIOS and Chipset drivers, can minimize audio output. Furthermore, manually installing audio drivers from an outside source can interfere with the quality output. Running a diagnostic check can fully provide users with any technical occurrences.
Solution: Run a diagnostic check through laptop's system settings in order to fix any issues. Update or reinstalling drivers may be necessary.
Faulty Speakers
There are two main problems: the external device or the laptop's built-in speakers. Physical damage from speakers will cause persistent audio distortion. An example of this is crackling noises. Moreover, sound does not display when using headphone port. When this occurs, it is best to possibly replace the speaker.
Solution: Replace the internal speaker on device, especially if issues are persistent.
Lenovo IdeaPad 1-15IJL7 Speaker Replacement
