crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Tablet won't turn on
Tablet displays battery drained indication
Plug power adapter into the wall
Plug the cable into the tablet and the wall adapter into the wall. Let it charge for about 20 minutes. Make sure you are using the genuine Lenovo power adapter. Some phone chargers won't provide enough power to the tablet.
Issue with charger and wall adapter
Try plugging the cable and wall adapter into another device. if the other device does not turn on, then it is probably a faulty wire that is causing your issue. You may purchase another charger from the Lenovo website.
Reboot the tablet
Rebooting the tablet will take it to a point in time where it was working, basically it makes the tablet think it's "brand new." Locate the small pin hole located within the SD card holder. Using a small, but not sharp, pointed tool, depress the pin hole for 5-10 seconds and turn on the tablet.
Faulty battery
If your tablet battery is still showing drained, and you've tried everything else, your tablet might have a faulty or broken battery. In this case there isn't a whole lot you can do as a whole besides replacing the battery or buying a new tablet.
Frozen black screen
The old "Black Screen of Death" strikes again
Tablet battery is drained
If the battery is dead, the screen won't turn on. Plug the cable into the tablet and the wall adapter into the wall. Let it charge for about 20 minutes. Make sure you are using the genuine Lenovo power adapter. Some phone chargers won't provide enough power to the tablet.
Using the wrong charger
Make sure you are using the genuine Lenovo power adapter. Some phone chargers won't provide enough power to the tablet. If you are using the genuine charger, try plugging the cable and wall adapter into another device. If the other device does not turn on, then it is probably a faulty wire that is causing your issue.
Reboot the tablet
Faulty battery
Power button is stuck
Food, dirt, and grime can all cause the power button to be stuck. Hold the button for 20 seconds and then let go. Wait 30 seconds before attempting to power it up again. If you do eat sticky food, or food in general, wash your hands thoroughly before handling our device.
WiFi connectivity issues
I can't get to the internet
Turn WiFi on
If the WiFI setting isn't on, then your tablet won't search for a signal. Go into your apps drawer and select settings. Then select WLAN and toggle it on. Tap the correct WiFi network and enter the password if required.
Turn Flight Mode off
Flight mode restricts every signal coming into and out of your device including WiFi, Blutooth, and cellular data. Go into your apps drawer and select settings. Then select more, airplane mode, and toggle it off if it is on. Then go into WLAN and toggle it on. Tap the correct WiFi network and enter the password if required.
The correct network
If you connect to another network besides your own, your password won't be correct. Make sure you are selecting the correct network and that your password is typed in correctly.
Router issues
Make sure all the correct lights are illuminated on the router. Try connecting to the WiFi network with another device, like a laptop computer or friend's phone. If any other devices can connect to and use the wireless network, the problem is most likely specific to your device. Check to see if your device can connect to a WiFi network at another location, like a friend's house or a public network. If it can, the problem is most likely specific to the WiFi network. If your router is pretty old, you might want to think about investing into a newer, faster router.
Reboot the tablet
Unresponsive camera
Can't take a picture or a video
Rebooting camera
If your storage is full, you won't be able to take and save any pictures or videos. Go into your photos app and delete all the photos. Reset all data in the menu. Check for any incompatible permissions in settings. If yes, uninstall the software and reboot system.
Make sure device is updated
Sometimes, an older software can be not supported by a company anymore, causing some features to not work. Update your devices software to the latest version in your settings.
Reboot the tablet
bro i got tablet boot loop cause i flashed wrong twrp file
cannot even hard reset
MAK AKSHAY - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My tablet is cracked repair please mail it to me
Brenda Brooks - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
