crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
If your Lenovo 14e Chromebook's battery drains rapidly whenever it is not directly plugged in to a power source, follow this page for solutions.
Power Intensive Apps/Programs:
  • Observe what apps or programs may be taking up the laptop's battery the most. Uninstall, or close these apps when they are not in use.
  • Unused apps and programs can also be prevented from running in the background. Go to the Settings app, navigate to Apps, then Installed Apps, and select the desired application. Select Advanced Options to then allow you to change the Background Permission settings.
Unoptimized Display and Battery Settings:
  • Ensure that your device is in low power mode/power saving mode, reduce the Chromebook's screen brightness, and minimize background or unused apps' usage.
Faulty Battery:
  • In the case of a damaged battery, a new battery may be the only way to solve the issue of the battery draining rapidly.
  • Overheating, overcharging, and physical or manufacturing defects may cause potential damage or swelling to the Chromebook's battery, and replacement is often required.
  • See Lenovo 14e Chromebook Battery Replacement Guide.
Caleb Watt
crwdns2935283:009/24/25crwdne2935283:0
335 crwdns2915208:0crwdne2915208:0
Texas Tech, Team 2-4, Johansen Fall 2025 crwdns2935289:0Texas Tech, Team 2-4, Johansen Fall 2025crwdne2935289:0
TTU-JOHANSEN-F25S2G4
crwdns2942667:0crwdne2942667:0 248
