Damaged Screen
The phone's display is damaged.
Cracked Outside Screen
If there is a visible crack across the glass screen, you have a cracked outside screen. If this is the case, you must replace the outside screen.
Cracked LCD Screen
If there is a crack in the display but not in the physical screen, then the likely cause is a cracked LCD or "inner" screen. The crack will result in the display turning blank either partially or entirely. If this is the case, you must replace the LCD screen.
Defective or Dead Pixels
If the image on the screen does not display correctly, you may have defective or dead pixels. If this is the case, you must replace the LCD screen.
Jammed Buttons
It is difficult to press the buttons.
Obstructing Debris
If pressing the buttons is difficult, or if the buttons are completely stuck, you may have debris in your buttons. If this is the case, you must disassemble the device and remove the debris.
Broken Keypad
If pressing the buttons is difficult or the keys don't respond when you press them, you may have a broken keypad. The keypad lies underneath the buttons and is critical for the buttons to work. If your keypad does not work, you will need to disassemble the phone and replace the keypad. See Keyboard Replacement Repair Guide.
Weak / No Signal
There is poor or no cellphone reception.
Bent Antenna
If you have a poor quality signal or no signal at all, you may have a bent antenna. A deformed antenna may affect the phone's signal and will need to be replaced.
Links to websites selling replacement antennas:
http://www.daydeal.com/product.php?produ...
http://www.cellphoneshop.net/reanforlgvx...
Faulty Antenna
If you have had a poor quality signal or none at all since the time you purchased the cellphone, you may have a faulty antenna. A faulty antenna will affect the phone's signal and you will need to buy and install a new antenna. See Antenna Replacement Repair Guide.
Missing Antenna
If you never pick up cellphone reception, you may be missing your antenna. There should be a one-inch, gray antenna on the top-right corner of the cellphone. A missing antenna will affect the phone's signal and you will need to buy and install a new antenna.
Poor/No Audio
There is distorted or no sound coming from the phone.
Faulty Speaker
If your speaker has distorted sound quality, then the problem was most likely caused by the manufacturer. If you have a faulty speaker, you must either contact the cell phone dealer or replace the speaker. See Speaker Replacement Repair Guide.
Cell Phone Manufacturer's Website:
http://www.lg.com/us/support/index.jsp
Broken Logic Board
The device functions are not working correctly or responding properly.
Broken Logic Board Component
If one or more components of the logic board are damaged or broken in any way, the entire logic board must be replaced. You may not have the skills, tools or the time to fix the broken logic board and replacing it is the easiest way. See Logic Board Repair Guide.
Tyler
crwdns2935283:004/09/10crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 34-58, Forte Spring 2010 crwdns2935289:0Cal Poly, Team 34-58, Forte Spring 2010crwdne2935289:0
CPSU-FORTE-S10S34G58
crwdns2942667:0crwdne2942667:0 1,527
