crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Earphone falls out of the device
Movement of the device causes the earphone to fall out.
Obstruction in the earphone cavity
Clean/wipe the surface between the earphone and the magnet inside the device.
Bad Magnet
If the earphone still will not stay in place, the magnet inside the device may need to be replaced.
Device is not functioning
Frayed or worn out wires causes the device to not function properly.
Break in one of the connecting wires
Strip the material covering the wire off, and use wire splicing techniques to merge the break in the wire segment.
Device is not charging
Battery light is violet or red after device has charged for two hours or more.
"If not able to charge, change the power source of the charger/power cord."
Charger is not working
Inspect the charger for obvious signs of malfunction such as burned or frayed wire.
Charger Port is not working
If the charger seems to be in working order, use a pin or small screwdriver to locate the lead inside the charger port. If it is bent, attempt to bend it back to its normal state.
Andrew Oglesby
crwdns2935283:003/31/15crwdne2935283:0
267 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-2, Shastany Spring 2015 crwdns2935289:0UMass Dartmouth, Team 2-2, Shastany Spring 2015crwdne2935289:0
UMASSD-SHASTANY-S15S2G2
crwdns2944067:054crwdne2944067:0
my headset keep saying vibrate off
Garrett Stewart - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
The stock ear-pieces have thinly-braided, enameled leads, given color at one end of a single wire to denoted (+). I don't know whether that polarity-color-label extends into the covered length, that might be frayed. But if it does, then your greatest challenge might be, in de-insulating that kind of wire. Its insulation consists of a thin but tough, transparent coating. I found in my youth, that the easiest way to do that, was actually to hold a cigarette-lighter-flame to it for a few seconds. After that, you might be able to "splice" it, if you apply very good dexterity.
Dirk Mittler - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My HBS-750 is not connecting with Bluetooth or sometimes disconnecting after being connected. At the same time it started altering its voice. When the device say "Power On.... Trying to connect" it has now started to say it in a very high pitch or a very low pitch. When it says that in an abnormal pitch it will not connect via Bluetooth.
Doug Barrineau - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Headset was working great until a phone call. It is charged and connected but will not play
jodyk - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 63,287
