crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Return to the LG Stylo 2 Repair Guide
Poor Battery Life
The phone is dying very quickly and barely holding a charge
Too Many Active Apps
Your phone battery might be under a lot of stress because of the amount of apps running all at once. A good solution is closing out the apps you aren't currently using and seeing if the issue still persists.
Faulty Battery
If cleaning the holding-bay/battery power input and the battery power output does not solve solution battery many be faulty. Replacing the battery may be the solution. How to replace battery.
Unresponsive Touch Screen
The screen does not respond to touch commands
Physical/Internal Damage On the Touch Screen
Due to external damage from; magnets, dropping of phone, or any other cause of screen damage may have caused disconnects from the screen and the internal touch sensors. Replacing the screen may fix this problem.
Phone Apps Causing Crash
Having too many applications open at once may cause the processor to overload, opening an app that is too big for the phone to handle, or downloading an application that may be infected with malicious malware may be the cause. A simple solution would be to close out of apps you are not using or close all applications before using a desired application. If problem still occurs then a virus might be present and other guides of curing the phone will be necessary.
The Phone Does Not Charge
Phone failing to charge when plugged in or dying while plugged in
Charge Port Blocked By Dirt
It is common for lint and dust to collect in the charge port over time. This build up can block the connection between your charger and the phone’s port. Your best remedy is to find a flashlight and clean out the port with something sturdy like a dental pick.
Faulty Battery
Most cell phones use lithium ion batteries which age rapidly with daily use. If you’re noticing inconsistent battery percentages after charging the phone for a prolonged time, you may need to replace the battery. For the best how-to, check out the guide here.
Charge Port Physical Damage
If you’re finding it hard to plug in your phone into the charger you may want to check the port for any physical damage. For reference you can always do an image search for what the port is suppose to look like versus how your port currently looks.
Faulty Charge Port
If all else fails you may need to replace the charge port itself. For step by step instructions check out the guide here.
Major OS Freezes
The phone is freezing up and is unresponsive when in use
Cache Overflow
Clearing application cache frees up space and improves performance of application.
Phone Is Stuck Boot-Looping
The phone stuck loading while booting up and unresponsive
Safe Mode
Safe Mode puts your phone in a diagnostic state.
Faulty Motherboard
The motherboard might be physically damaged due to and physical harm including water damage a guide to replace the motherboard can be found here Here.
Camera Not Capturing
Camera screen is black/foggy or has cracks through the picture
Camera App is Frozen
The camera application itself might be frozen. Closing the application completely may solve the issue.
Camera is Physically Broken
The camera or camera lense may be physically damaged and will need to be replaced. A replacement guide can be located here.
Mark Sapp
crwdns2935283:002/13/18crwdne2935283:0
60 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
USF Tampa, Team S11-G1, Cheng Spring 2018 crwdns2935289:0USF Tampa, Team S11-G1, Cheng Spring 2018crwdne2935289:0
USFT-CHENG-S18S11G1
crwdns2944067:08crwdne2944067:0
I just replaced the lcd screen myself on a lg stylo 2 phone. Now i have no sound unless i use headphones help please
theresa1161961 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
You probably bent one of the prongs when putting your screen in, you'll have to take the screen out and bend that prong back and your sound will come back. I did the same thing.
Christene Davis - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I just replaced the lcd screen myself. Now i have no sound unless i use headphones. What could be
I jump want to know something my stylus 2 doesn't show anything and I thought it's lcd however someone whi was going to fix it told me that it's a manufacturing problem and it can't be fixed anymore. I want to know where can I take it to be fixed around Cape Town.
Akon - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
my stylus 2 wont charge or open after i remove my battery while rebooting how to fixed it?
ryoryo rya - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 39
crwdns2959996:0crwdne2959996:0 5,544
