There is no Sound
The volume is at its lowest or off
On the side of the phone push the volume button up to enable sound and audio.
The Phone is on Silent
In settings click settings, sound, and click silent to turn off silent.
Repair the Speaker
(Look into repair guide)
My battery won’t hold a charge
Try turning off your phone and charge it for a full charge cycle.
Hold the top right button until the device is off and plug the charger in a working outlet. then, plug the charger into the phone
Try resetting you're phone to factory settings after backing up all you're data. Then retry to charge.
In settings, general, restore phone. Then, enter your passcode and wait until the restore is finished.
The battery may be faulty, see the battery replacement guide.
My phone won’t turn on
Try using the wall charger.
Hold the top right button until the device is off and plug the charger in a working outlet. then, plug the charger into the phone.
Pull out the battery and hold the power button for 30 seconds.
The battery has been drained past its critical threshold. Your phone probably won't turn on until you get the battery back up to five percent or so.
Try another charger
Its possible the wall charger or cord is defective. If able to, test with a known working cable.
Bad display
It is possible that it appears nothing is happening because the display is bad. The display might need to be replaced.
My 3G keeps dropping
Andriod 2.1 with perfect 50% uptime for 3G
Due to a bug in andriod 2.1, some phones have faulty 3g programming. Rebooting the phone and placing it in airplane mode for 12 seconds solves the 50% uptime problem. This would have to be applied every time after reboots. Updating Android will fix this though.
Brian
crwdns2935283:010/30/13crwdne2935283:0
18 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
UMass Dartmouth, Team 1-2, Shastany Fall 2013 crwdns2935289:0UMass Dartmouth, Team 1-2, Shastany Fall 2013crwdne2935289:0
UMASSD-SHASTANY-F13S1G2
crwdns2936753:030crwdne2936753:0 35
crwdns2959996:0crwdne2959996:0 3,608
