crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Phone will not Turn On
No matter what you do, you can't get your Phone to turn on.
Phone May be Turned Off
If your Phone’s problem isn't so easily solved, read on.
Drained/Bad battery
If your Phone won't turn on, especially if it has not been used recently, you may simply have a drained battery. Plug your Phone into your AC (wall) adapter and see if anything happens. Ideally your Phone will recognize it has been connected to a power source and charge its battery. If it will no longer charge, the battery must be replaced.
Bad Display
It is possible that it appears nothing is happening because the display is bad. If the battery is working properly but nothing is visible, it is possible the display is bad and must be
Bad Logic Board
Ultimately, if the display and battery are not the culprit, check all the connections from the display to the logic board. If they are connected properly and there is still no life, the logic board most likely needs to be replaced.
Camera not Working
You open the camera, and you can’t see anything.
Camera App Has Froze
Simply exiting the camera, waiting for 30 seconds and then restarting the app by tapping on the app icon.
Camera is Blocked
It’s possible that something is covering the outside of the camera, which is preventing an image to appear on the screen. Assure that your finger, case, or anything else is not blocking the camera from capturing an image.
Phone Glitch
A common cause of application issues is a software glitch. If the camera has stopped working without any reason, then restart the device.
Faulty Camera
It’s possible the physical camera lens is faulty or damaged. It may need to be replaced.
No Audio or Distorted Audio
Your Phone turns on and appears to work, but when you plug in headphones or try to listen through the speakers, the audio doesn't play properly.
Faulty Headphones
It's unlikely your headphones or speakers are bad, but it's worthwhile to eliminate these as the source of your problem at the beginning. Try your headphones with another device to make sure that the problem is with the phone.
Faulty Audio Jack
The most likely cause of audio output problems on the Phone is a bad audio-out jack. First try a hard reset on the Phone to make sure it is not a software issue. If that fails to work, try replacing the audio jack or exterior speakers. If that doesn't solve the problem, your logic board most likely needs replacement.
Home or Volume Buttons not Working
You press the exterior buttons, but nothing happens.
Phone Glitch
Just turned it off and back on.
Case (if applicable) May Block Volume Buttons
Although unlikely, if a case is on the phone, it may be blocking or making it difficult to press down the volume buttons properly. It is necessary to remove the case and attempt to use the buttons again.
Faulty Buttons
The buttons might be damaged or faulty. They will need to be replaced.
No Display
The phone is turned on, but nothing shows on the screen.
Very Low Brightness
It is possible that brightness setting on your phone is low. To fix this issue, following the steps below:
  1. From any home screen, swipe left to locate and tap Settings.
  2. Select the Display tab or scroll to and tap Display.
  3. Scroll to the Brightness slider.
Screen Damaged
The screen has cracks or is damaged preventing the screen from turning on.
Vivek Kathrotiya
crwdns2935283:002/26/19crwdne2935283:0
741 crwdns2915208:0crwdne2915208:0
Purdue University Northwest, Team S2-G1, Hingst Spring 2019 crwdns2935289:0Purdue University Northwest, Team S2-G1, Hingst Spring 2019crwdne2935289:0
PNW-HINGST-S19S2G1
crwdns2944067:021crwdne2944067:0
phone is locked or frozen. There is a green square circled around and cannot swipe up to open
mary behrens - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
yes I just signed in but cannot open phone
Does anyone have the problem of the phone heating up when charging?
Tracee Banks July 19
tbanks65 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My phone is not charging let it should how can fix the problem
Robert Ronhoved - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 47
crwdns2959996:0crwdne2959996:0 5,871
