crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Cannot connect to Wi-Fi
You can't get your LG G3 Vigor to connect to Wi-Fi.
Wi-Fi is turned off
Wi-Fi must be enabled first in order to connect to a Wi-Fi network. This problem could be due to the fact that your device's Wi-Fi is turned off.
The router or Wi-Fi source may not be working or unplugged
There may be a problem with the router or the other source that is supplying the Wi-Fi or it could simply just be unplugged.
Wireless network password is incorrect
If the wireless network password is incorrect then your LG G3 Vigor will not connect to the Wi-Fi network.
Device won't charge
You can't get your LG G3 to charge.
Faulty Outlet
The outlet that you are trying to plug your charger into could be faulty and thus the reason that your device is not charging.
Charging port and battery contacts could be damaged
There could be some debris in the charging port that could be preventing your phone from charging. If the charging port looks to be debris free, the problem could be related to the battery or the gold contacts being dirty.
Broken Charger
The charging problem may not be your phone at all but due to the fact that you have a faulty charger.
Freezes or slows down
Your LG G3 is unresponsive or has slowed down.
Loose SD card
Sometimes the SD card can slow down the device and removing it will help. From the home screen tap the All Apps icon. From there tap on the Settings icon and scroll and tap storage. Find the option to Unmounted SD card tap it and hit OK. Then remove the SD card from the phone.
Too many open applications on
Some apps run in the background and slow the devices performance down, removing them can help with performance.
Device won't turn on
Your LG G3 Vigor won't turn on.
Unresponsive power button
The power button may be broken and need to be replaced.
Charge the battery
The device won’t turn on when the battery is uncharged. To charge the battery, we need to plug the device into a computer or AC adapter and see if the battery is charging.
Dead battery
The battery might be dead and need to be replaced. If the device suddenly turned off, or the battery dose not last long, these are signs of a faulty battery. When the battery is no longer charging, then the battery will need to be replaced.
Troubled display
The device might be working and the battery is charged, but the display is non-responsive or faulty . We can try to charge the device and press the power button and see nothing change. In this case, bring the device close enough to hear the device is working. If that’s happened we know that the problem is the display, and it will need to be replaced.
Speakers not working
Your LG G3s speakers are not working or producing sound.
Faulty Speakers
The first thing to check when realizing that the speaker on the LG G3 Vigor is not working is to go right to the source and check the speaker to see if there is any debris blocking the speaker and preventing it from making sound. The speakers may be broken and need to be replaced.
Sound may be off
Your devices volume may be all the way down or it is on a silent or mute mode. Try and locate the audio settings for your LG G3 Vigor and check to see if it is in any of those modes.
Outdated Software
A common problem that usually leads to the device not performing up to standards is that the software it could be running on is old and has bugs that cause these hiccups. That being said make sure that your phone is up to date on software updates and if not try updating your phone to the most up to date software ( MAKE SURE TO BACKUP DEVICE PREVIOUS TO UPDATE IN ORDER TO ENSURE THAT NO DATA IS LOST)
Ian Hunter
crwdns2935283:002/08/16crwdne2935283:0
124 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
USF Tampa, Team 12-5, Eyestone Spring 2016 crwdns2935289:0USF Tampa, Team 12-5, Eyestone Spring 2016crwdne2935289:0
USFT-EYESTONE-S16S12G5
crwdns2942667:0crwdne2942667:0 1,712
