Loose or Faulty Pieces
A piece of the gun does not seem to stay in place or function properly.
The O-ring is Detached or Deformed
If the orange cap is loose or falling off, then the o-ring is probably missing or deformed. The o-ring must be fitted back to the shaft, and the orange cap can be press-fitted back onto the o-ring.
Return Spring for the Barrel Shield is Detached
If the barrel shield if sliding freely on the gun, there is an issue with the return spring. The device must be opened and inspected for the faulty spring. This should be attached to the bottom of the barrel shield. Reattach the spring and the issue should be resolved.
Gun is Not Firing Properly
My gun will not fire when I load and press the trigger.
The Ring was Inserted Backwards
The ring may be inserted, facing the wrong way. This will prevent the gun from firing. Remove the ring and insert it facing the proper direction.
The Projectile is Deformed
It is possible that the projectile is deformed or loaded improperly, causing the mechanism to jam. Remove the projectile and inspect for defects. Insert the projectile back into the gun and try again.
The Spring is Detached From the Release Lever
If the gun does set when the loading lever is pulled back, the issue is most likely with the loading mechanism. Pull the trigger to ensure that the loading mechanism is not already set. If it is already set, the trigger should release the mechanism, returning the gun to its unloaded state. Proceed to load and use as normal.
If this does not resolve the issue, then the problem is with a spring inside the gun. The spring attached to the release lever is responsible for locking the loading mechanism in place. You must open up the device and find the faulty spring. It has most likely become detached from its original mounting position. Reattach the spring and it should work as normal.
The Return Spring for the Trigger Release is Detached
If the trigger is stuck or not resetting when you pull it, there is most likely an issue with the internal spring. The spring is either detached, dislocated, or missing. The gun must be disassembled and inspected for the defect. When the spring is properly reattached, reassemble the gun and proceed as normal.
Lingbin Meng
crwdns2935283:002/16/16crwdne2935283:0
204 crwdns2915208:0crwdne2915208:0
IUPUI, Team 2-4, Harley Spring 2016 crwdns2935289:0IUPUI, Team 2-4, Harley Spring 2016crwdne2935289:0
IUPUI-HARLEY-S16S2G4
crwdns2935297:036crwdne2935297:0
crwdns2959996:0crwdne2959996:0 767
