Kodak Easyshare M530 TroubleShooting
A possible problems guide for the Kodak Easyshare M350 will be made for the user to go to incase such stated problems arise.
Camera won't turn on
No matter what you do, you can't get your camera to turn on. It may be possible that either the battery needs to be charged or replaced. If it is not the battery then there may be something wrong with the buttons. The buttons may be sticky or may need replacing as well.
Drained/bad battery
If your camera won't turn on, ....It may be possible that your battery is dead. To check this, simply turn the camera upside down and release the battery hatch to switch out your current batteries. Check to make sure your batteries are inserted correctly and/or charged. Once this is done, close the hatch and turn the camera on again.
Bad display
It is possible that it appears nothing is happening because the display is bad. The image may also be out of focus. Simply turning auto focus on would solve this problem or move within range of the image being taken. If the display is cracked or water damage, the display must be replaced. In this instance, parts would need to be purchased to replace the damaged ones.
The captured image is not stored in memory
It is possible that before the image is saved, the power has been shut off. The solution to this would be when the battery indicator turns red, replace the battery.
Buttons become inactive
It is possible a short circuit occurred when connecting the camera with other devices. The solution would to this would be to remove the batteries from the camera and then re-insert the batteries again.
Elizabeth
crwdns2935283:001/28/15crwdne2935283:0
297 crwdns2915208:0crwdne2915208:0
Penn State, Team 1-2, Kaschak Winter 2015 crwdns2935289:0Penn State, Team 1-2, Kaschak Winter 2015crwdne2935289:0
PSU-KASCHAK-W15S1G2
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 47
crwdns2959996:0crwdne2959996:0 2,173
