crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
If the battery in your Kindle Paperwhite 12th Gen drains quickly after minimal use even after it is fully charged, follow this troubleshooting guide for potential solutions.
Software is Out of Date
Make sure your Kindle is up to date with software updates. If the device is trying to run on an older version of the software, it may take more power and battery life to function, causing the battery life to not last as long and to drain quicker.
Incorrect Settings
Enabling airplane mode will prevent unnecessary network searching that is potentially draining the device’s battery when it is not being used. You may also try adjusting the screen brightness to a lower setting.
Automatic Page Refresh Enabled
Disable the automatic page refresh feature on your device when not needed. This feature could be causing battery drain when not necessary.
Too Many Background Apps
If you have any active apps running in the background that you're not using, try closing them to minimize battery drainage. Having apps run in the background of your device can make it work harder than it needs to run, causing the battery to drain faster.
Unnecessary Features Enabled
Review your device’s settings and disable any features you are not using, for example, text-to-speech or experimental features.
Software Glitch
If none of the suggested methods have worked, try force restarting your device. To do so, hold down the power button for 40 seconds until the screen turns black. To turn it back on, simply press the power button again. Restarting your device may help because it could help refresh the device's software and could potentially fix any glitches that were taking place that were causing the battery to drain abnormally.
Battery Failure
If you've adjusted the various settings and the battery is still draining fast, follow this guide to replace the battery.
Ruby Powell
crwdns2935283:002/23/25crwdne2935283:0
197 crwdns2915208:0crwdne2915208:0
Austin Community College, Team 18-1, Watkins Spring 2025 crwdns2935289:0Austin Community College, Team 18-1, Watkins Spring 2025crwdne2935289:0
AUSTINCC-WATKINS-S25S18G1
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 81
crwdns2942667:0crwdne2942667:0 1,118
