crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
If your Keychron K2 Wireless Mechanical Keyboard will not turn on, follow these precise, step-by-step troubleshooting instructions:
Keyboard is Powered Off
Check along the left edge of your keyboard right next to the Caps Lock key for the power switch and make sure the switch is on either "BT" or "Cable," depending on whether you want Bluetooth or a wired connection. The device should then be on.
Keyboard Not Charged
Go ahead and plug in your keyboard using a USB-C cable on the left side of the keyboard. A red light should appear right next to the charging port, indicating that it is being charged. Wait a couple of minutes to see if it turns on. If no light appears, try using a different USB-C cable or a different power adapter to rule out a faulty charger.
Incorrect Pairing Setting
Check along the left edge of your keyboard; right next to the Tab key, there is a switch that determines the bluetooth connection used for your device "Win/Android" and "Mac/iOS." Make sure you have the correct option for your respective computer/device.
Faulty Charger
Make sure the USB-C charger you are using is working properly. Try using it to charge other devices that are compatible with USB-C to see if they charge. You'll know if the keyboard is charging if a red light comes from the side. The charger port is below the escape key, the red light will appear in between the charger port and the "Win/Android" and "Mac/iOS" switch.
Charging Port Condition
Inspect the USB-C port on the left side of the keyboard. See if there is any debris, dust, dirt, or anything that could prevent the keyboard from charging. If so, try blowing into the port to remove fine dirt or dust particles, or if you have a fine brush, try getting as much of the debris out as you can. Be careful not to insert anything metal into the port, as this could damage the internal connectors. Follow this detailed guide for instructions on cleaning the ports in your electronic device
Faulty Battery
After completing a certain number of charging cycles, the battery powering the keyboard may become less effective. This can result in the battery losing power quickly or the keyboard no longer functioning wirelessly. In order to resolve this issue, the battery will need to be replaced.
Zachary Miller
crwdns2935283:002/05/26crwdne2935283:0
247 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
Texas Tech, Team 11-4, Weston Spring 2026 crwdns2935289:0Texas Tech, Team 11-4, Weston Spring 2026crwdne2935289:0
TTU-WESTON-S26S11G4
crwdns2936753:030crwdne2936753:0 125
crwdns2959996:0crwdne2959996:0 854
