crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Keurig Will Not Turn On
No matter what I do, the Keurig simply does not turn on.
Faulty Power Cord
Make sure that the power cord to the device is intact and is correctly inserted in a wall outlet. Press the power button to turn the device on. If the cord is plugged in but the device still does not turn on, try switching the cord to a new outlet.
K-cup Chamber Will Not Close Properly
I put the k-cup inside the device but it will not close shut.
Deformed or Incorrectly Placed K-cup
Double check that the k-cup is positioned correctly by taking it out or rotating it. If it is still not closing, look over k-cup for deformities. Replace the k-cup if needed.
Device Does Not Brew A Full Cup
The coffee maker will only brew a partially filled cup.
Incorrectly Positioned K-cup
First open the chamber where the k-cup is placed. Then make sure that the cup is fitted correctly in the chamber to allow the needle to puncture the cup.
Clogged Needle
Remove the cup in the chamber and take a cotton swab and remove the built-up residue around the needles.
All Indication Lights Are On And Flashing
After turning the device on, the indicator lights begin to flash on and off.
Filled or Dirty Water Reservoir
Before attempting to take apart the device, unplug the device from the power source and drain the water reservoir.
Damaged Water Reservoir
Pay attention to any damage such as cracks in the reservoir or if the bottom filter is blocked. Remove any blockage from reservoir and clean with soapy water. Fill the reservoir up to the max line after cleaning and seat the reservoir in place.
Water Is Leaking From The Chamber
After brewing begins the coffee maker is leaking water.
Normal Functions Of Machine
This device will produce some condensation from the hot liquid being dispensed, and some fluid retention in the device and in the drip tray are common.
K-cup not Punctured Correctly
If the needle is dirty it may not puncture the k-cup correctly. Take out the k-cup and clean the needle with a cotton swab.
Machine Is Malfunctioning And Leaking
If this is the case, a repair will most likely be necessary as the chamber or the dispenser/k-cup holder is most likely damaged.
jonathan
crwdns2935283:002/08/16crwdne2935283:0
816 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 6-1, Eyestone Spring 2016 crwdns2935289:0USF Tampa, Team 6-1, Eyestone Spring 2016crwdne2935289:0
USFT-EYESTONE-S16S6G1
crwdns2944067:046crwdne2944067:0
my machine just leaks out of the bottom when its brewing
connie roberts - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My machine is leaking when filling my coffee around filter
austrocatering - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I found when this happens I filled the pod too full or I needed a new pod. Hope this heps.
sweetbrat58 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
It is turned on but there is a circle light on the bottom right. . The cup is in correctly. This happens every time I unplug thr machine
Anita. Riet - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My Keurig is turned on. Their is a circle light on the bottom right. The cup is fit securely and water is filled. But it will not begin brewing
crwdns2936753:030crwdne2936753:0 86
crwdns2959996:0crwdne2959996:0 43,155
