Coffee Not Hot Enough
Heating Mechanism Shut Off
If your coffee is not brewing as hot as it should be, then your heating mechanism has probably shut off. This is due to your water pump functioning incorrectly. When water is not being pumped through the brewer, the heating device shuts off to prevent the coffeemaker from overheating. Similarly, if the water pump is working but not at max efficiency, the coffeemaker signals the heating device to shut off. You will have to reseat your water reservoir.
Device Makes a High-pitched Noise
Scale Buildup on Water Pump
The Keurig B77 could be making a higher pitched noise because the pump has to force water through a smaller opening to deliver the water to the K-Cup. This is due to a build-up of scale in the tubing. You will need to clean out your device with white vinegar.
Won't Brew a Second Cup or Shuts Off Randomly
Water Reservoir Magnet out of Place
When you try to make a cup of coffee right after another cup, the 2nd cup is not made fully or does not get made at all. This generally occurs when the magnet holding the water reservoir in place vibrates out of its original spot. To fix this, you will have to realign the magnet holding the water reservoir in place.
Does Not Brew Full Cup, or Cup is Mostly Water
If your machine has difficulty brewing the entire cup or fills it with mostly water, then it is probable that your pump is being clogged with scale, which obstructs the flow of the liquid in the device. You will need to clean out your device with white vinegar.
Paul Doyle
crwdns2935283:001/20/11crwdne2935283:0
540 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 5-17, Amido Winter 2011 crwdns2935289:0Cal Poly, Team 5-17, Amido Winter 2011crwdne2935289:0
CPSU-AMIDO-W11S5G17
crwdns2931471:06crwdne2931471:0
crwdns2935297:084crwdne2935297:0
crwdns2944067:07crwdne2944067:0
Turn on it runs for a minute then shuts off
JoAnn - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Not ready warning but pumps water until empty. Will not heat water
Peter Hastings - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
When the not ready light turns off the machine shuts off. what could be the problem?
Deidra Shepard - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My 2.0 starting a high pitch squealing sound after I descaled it. I should have left it alone.
deb_rapisarda - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 36,333
