crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Battery Fails to Charge
The device is plugged into a power source, but the battery won’t charge.
Bad Battery
Batteries degrade over time. If the power light fails to illuminate and the speaker won't make any noise the battery may be dead. Open the device and replace the battery.
Bad Charging Cable
Wear to the power cable may cause it to fail. If the cable exhibits signs of wear and the device fails to charge, try using a new cable to see if the device will charge.
Broken Charging Port
Charging port on the device may be broken due to wear. Disassemble the device and replace the charging port.
Bluetooth Connection Doesn’t Work
Cannot pair other devices via Bluetooth.
Too Many Devices
Another device may be connected to the speaker. Check for nearby devices and unpair them, then try to pair your preferred device again. You can force an unpair by reseting the device to factory defaults. See below how to do this.
Damaged Bluetooth
The Bluetooth chip in the device may be damaged. A damaged chip will prevent the device from pairing via Bluetooth. Disassemble the device and replace the Bluetooth chip.
Device Needs To Be Reset
While the device is powered on, press and hold the ‘Play’ and ‘Volume Up’ buttons simultaneously for 5 seconds to factory reset the device.
Audio Issues
Vibration in the speaker, intermittent sound, or no sound at all.
Check that the Battery Holds a Charge
Check the power light on the device to make sure it's maintaining power. If the device loses power quickly after charging, the battery should be replace.
Adjust Screws Around Speaker
If there is a buzzing or rattling sound, disassemble the device and make sure that all screws surrounding the speakers are tightened. Loose screws may contribute to audio buzzing.
Inspect Speaker Wire
Disassemble the device and inspect the speaker wires to make sure they are not broken.
Check for Speaker Damage
Inspect the speaker for cracks or debris. If the speaker is damaged, disassemble the device and replace the speaker.
No Sound at All
If the power light is illuminated, but the speaker makes no sound, disassemble the device and verify that the wire connecting the speaker to the mainboard is intact.
Audio Issues When Using Aux In
Garbled sound or no sound at all when using the Auxiliary Input (Aux In) port.
Clean the Aux In Port
Locate the port labeled “Aux In” and use compressed air to clean out any dust or dirt that may be trapped in there, then try using the port again.
Check Aux In Connection
Make sure that the Aux In cable is seated properly and has a steady connection. If the Aux In connection has persistent issues, it may be damaged. Open the device and replace the connector.
A Button Doesn’t Function
Pressing a button has no effect.
Attempt to Unstick the Button
The button may be stuck. Turn off the device and lightly press the button for several seconds. Attempt to unstick the button by gently pressing it repeatedly. If the button fails to respond or responds only intermittently, disassemble the device and inspect the rubber membrane and contacts for wear, Replace as necessary.
Clear Any Debris
There may be debris blocking the button’s contacts. Disassemble the JBL Xtreme and clear any debris around the buttons, membranes, and contacts.
Ross Volenec
crwdns2935283:002/15/17crwdne2935283:0
1,393 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
USF Tampa, Team 1-1, Sullivan Spring 2017 crwdns2935289:0USF Tampa, Team 1-1, Sullivan Spring 2017crwdne2935289:0
USFT-SULLIVAN-S17S1G1
crwdns2944067:0273crwdne2944067:0
My speaker Buzz is real hard on the right side when the bass hits . Percussion cone on the outside is probably cracked or damaged how do I repair it and where do I buy a new one
Michael Hubbard - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Have you found an solution already?
Sem Sperber - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
In fact I already watched the video on how to repair it I just need to buy a new one. My address is 4653 Edwardian Circle apartment 2A Indianapolis Indiana 46254 I really like both my speakers and would love to continue using your product Michael Hubbard.
I wouldnt bother bro, getting a new one bro. Get a different speaker as jbl seem to just be a problem for most people. Mine keeps cutting out. They are obviously a load of junk
Dieter Pollard - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
The cutting out I found to be a tweeter issue on my Xtreme, replaced the 2 tweeters and no longer cutting out.
Marwan Mustafa - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 71
crwdns2936753:030crwdne2936753:0 373
crwdns2959996:0crwdne2959996:0 328,315
