crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
If your JBL Live 660NC headset isn’t charging, the problem could be related to the charger, charging port, or battery. This guide will help you identify the cause and go through possible solutions.
Debris on the port
Dirt and dust can build up inside the charging port, preventing the cable from making proper contact. Use a small non-metallic object (wooden toothpick), and compressed air to gently clean the port. Follow this next guide to clean the port.
Broken charger
A faulty or damaged charging cable or adapter can stop power from reaching the headphones. Try a different cable and wall adapter to check if the issue is with the charger. If it works with the new cable or adapter, the original items are defective and should be replaced.
Damaged battery
If none of the above steps work and there’s no indicator light while charging, the internal battery may be damaged or worn out. A battery replacement may be required to restore charging functionality. Follow this guide to replace the battery.
Damaged charging port
If the cable fits loosely or the port feels wobbly, the charging port itself may be damaged. In this case, the port might need to be replaced. Follow this guide to replace the charging port.
Alexander Diaz
crwdns2935283:010/01/25crwdne2935283:0
221 crwdns2915208:0crwdne2915208:0
Austin Community College, Team 10-4, Watkins Fall 2025 crwdns2935289:0Austin Community College, Team 10-4, Watkins Fall 2025crwdne2935289:0
AUSTINCC-WATKINS-F25S10G4
crwdns2936753:030crwdne2936753:0 47
crwdns2942667:0crwdne2942667:0 471
