crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Buttons are unresponsive
JBL Flip 3 buttons are not working
Possible underlying causes
Check that device is powered on
Check to make sure that your device has been turned on.
Check battery to see if it is dead
Check the device’s battery to see if it may be dead, and charge or replace the battery as needed.
Consider Any Exposure Device Has Had to Water
Although the JBL Flip 3 speaker is splash-proof, buttons may become unresponsive if they have experienced extended exposure to water - e.g. the device has been submerged in water rather than simply splashed.
Sound cuts out
Audio plays intermittently or drops out suddenly
Bluetooth connection at edge of, or beyond range
If your device is outside of the working range of the bluetooth transmitter, the sound may cut in and out, or drop out suddenly.
Objects interfering with bluetooth signal
Large and/or dense objects between the JBL Flip 3 and the source of audio may interfere with signal transmission, resulting in cuts and drops in audio. Ensure a clear, unobstructed path from the source to the JBL Flip 3.
Device won’t charge
Device battery wont retain, or begin to charge
Check outlet
Ensure the charging cord is properly plugged into a functional outlet.
Check charging cord
If there are exposed wires on the charging cord, or if the charging cord has experienced some trauma, then the problem may stem from the charger rather than the device itself.
Plug in properly
Make sure the cord is plugged in the device all the way.
Unresponsive Bluetooth
JBL Flip3 won’t connect to Bluetooth properly
Turn on device
Ensure that the device is turned on properly
Unplug any conflicting speakers
Check to see if you have headphones or an overriding AV cord into whatever you are attempting to connect to the JBL Flip
Reconnect music player to speaker
Delete the Flip Speaker from your device’s Bluetooth’s memory and reconnect
Distance from Speaker
Ensure that you are not too far away from the speaker to properly connect
Device won’t turn on
The device will not respond to the power button being pressed.
Battery is Broken
The battery may be broken and need to be replaced. (Link to battery replacement page)
Short Circuit
A circuit may have broken due to potential water damage, resulting in the need to replace the circuit board. (Link to circuit board replacement page)
Device isn’t charged
Plug the device into the charger. Allow the device to charge before attempting to turn on the device again.
Charging cord is faulty
Plug in the device with a new charger to check if the fault is in the device or the charging cord.
Reset the Device
Hold the power button for approximately 30 seconds to reset the device. The device may begin functioning after resetting.
Ivan Jones
crwdns2935283:002/20/17crwdne2935283:0
3 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
USF Tampa, Team S1-G2, Leahy Spring 2017 crwdns2935289:0USF Tampa, Team S1-G2, Leahy Spring 2017crwdne2935289:0
USFT-LEAHY-S17S1G2
crwdns2944067:089crwdne2944067:0
its been only one week i bought the jbl flip 3. i bought it from japan and brought it in Bangladesh through my cousin. After using it from the 1st day, i have been facing the problem, its taking "auto restart" even though having enough charge left on the speaker. But if i play the speaker connecting through charger, it isn't making any trouble then.
I am looking for urgent solution for the problem.
(P.S. i have updated the firmware version of the speaker too)
Mehedi Hossain Onik - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I am having same problem … how did you solve it ???
Joshi Namdev - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Please tell me how find JBL flip 3 battery and how to replace it ???
Gaurav Kushwaha - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My speaker isn't charging. It's new and on its second charge and the first light goes on when it's connected to power and it flashes but after leaving it charge for an hour or two the same light is still flashing and when try to turn it on the red light comes on and then goes off again.. what do I do?
Taylor - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 39
crwdns2936753:030crwdne2936753:0 152
crwdns2959996:0crwdne2959996:0 200,496
