crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Unable to Power On
The camera will not turn on.
Defective Battery
Ensure the battery is fully charged, and that it is connected to the proper +/- terminals. If the camera still does not power on, the battery is defective. See our battery replacement guide.
Insecure Battery Contact
If the battery is not securely connected to the proper terminals, it will not deliver power to the camera. See our battery contact replacement guide.
Blinking E
There is a blinking 'E' in the film counter window.
Insecure or Unrecognizable Battery or Film
The battery or film are either not recognizable types, or are not secure in their compartments. Make sure the device is off, remove the battery to reset it, and then load a new set of film. See our film cartridge replacement guide. Put the battery back in the camera, and turn it on.
If the issue is still apparent, contact the manufacturer for a replacement battery.
Defective Lens Unit
If the camera has been dropped, the impact can damage the lens unit by cracking the lens or bending the track on which the lens travels. See our guide on lens unit replacement.
Photos are Blurry
The subject of the photo is not clearly pictured.
Not Within Focus Range
The subject of the photo must be at least 60 cm away from the camera lens. If a closer photo is needed, attach a close-up lens.
Insufficient Lighting
Move to a spot that illuminates the subject more, or where the light is more evenly distributed.
Dirty Lens
If there are smudges on the lens, use a microfiber cloth and a few drops of lens cleaning solution to wipe the lens--starting at the center and spiraling outward.
If there is dirt or dust on the lens, gently remove it with a soft-bristled brush or a can of compressed air.
Remember that the key to a clean lens is prevention. Try to minimize all contact with the lens, especially cleaning.
Photos have Spots
A few spots appear in a line across the photo.
Dirt on the Film Roller
Foreign objects can get stuck on the film roller if the camera is not kept in a clean environment. Try to remove these impurities with compressed air. If this does not work, do not attempt further repairs. Contact the manufacturer for a solution.
Photos are Too Dark
Once printed, photos appear too dark.
Incorrect Lighting Mode
Check the lighting mode on camera to see if the mode matches the specific environment. For example, the indoor lighting mode is used for a poorly lit environment.
Flash and Light Sensor Blocked
If the flash and the light sensor in the front of the camera are blocked, photos will come out dark. Make sure nothing gets in between the flash and the subject of the photo.
Photos are Totally Black
Film ejected from camera has no picture, just black.
Defective Motherboard
Replace the motherboard of the flash. Do this by removing all of the external screws to expose the flash device, as well as the motherboard in question. Contact the manufacturer for a replacement motherboard.
Defective Capacitor
If the flash motherboard is not the problem, then it is likely that the photo flash capacitor does not hold charge anymore. See our capacitor replacement guide.
Shutter Failure
The shutter may have gotten stuck, resulting in a completely black photo. Contact the manufacturer for a solution.
Photos are Blank or Too Bright
Once printed, photos are white or brighter than they should be.
Film Cover Not Closed Properly
The film cover may not be closed properly. If any excess light enters the film, it causes the photos to be too bright when developed.
Premature Removal of Film Cartridge
Never remove the film cartridge if there is film remaining. This will expose the film to light, rendering it useless.
Reflective Surfaces and Bright Lights
If a photo is taken towards a reflective surface or a bright light, the film will be overexposed.
Elliott Tegan-Tawney
crwdns2935283:002/28/17crwdne2935283:0
690 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S2-G1, Nance Spring 2017 crwdns2935289:0USF Tampa, Team S2-G1, Nance Spring 2017crwdne2935289:0
USFT-NANCE-S17S2G1
crwdns2944067:040crwdne2944067:0
Just bought the mini 90- does really well but the self timer doesn't work. Press the button and nothing happens. Any suggestions?
Ann coffey - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Ann! Oldish comment but im having the same issue, did it work with film on it?
Silvia Amado - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have the Instax Mini 90 Neo Classic. Charged the battery to Full (green light on battery charger) and then inserted the battery into the camera. When inserted, the icons on the LCD turn on for a few seconds but then turn off. When I turn on the camera with the power button, the lens comes out, but then immediately goes back in and closes. I initially thought it might be due to film cartridge not being there and loaded a brand new cartridge. The camera then spit out the black cover of the cartridge but still the camera won't stay on. I have tried replacing the battery and that has not worked either. Would really appreciate help on this! Thank you!
Leah Stokes - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hi,
I have exactly the same issue. Please if you know any solution let me know, I will advise you If I find sth. Good luck
Lucho - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I had the same issue. The lens came out and immediately went back. So i openend the camera and tried to find something that can cause that error. For the disassembly i used the first steps of the lens replacement guide. First i found nothing. Then i noticed that the ribbon cable on the right side on the lens wasn’t correctly inserted. I put it out, reinserted it and voila, now the camera works again :-) I think it was that loose cable that caused the error.
When you try the dame be extra careful not to break the cables. There are also some small cables that can easily break
Tom Phobos - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 54
crwdns2936753:030crwdne2936753:0 196
crwdns2959996:0crwdne2959996:0 65,918
