Husqvarna models from 2009 onwards have an Autotune feature which automatically calibrates the carburetor. If you are running your saw in new weather conditions or at a different elevation, follow the steps to correctly tune the carb:
Reset Husqvarna Autotune
For low idle settings, start the saw.
  • Let it run for a few seconds to warm and then kick off the high idle by pulling the throttle.
  • Start a three minute timer. At the end of three minutes your idle should be tuned.
High Speed Procedure
For the high speed or full throttle reset, you'll have to make a large or long cut.
  • Bury the tip of the bar a few inches and run a six foot cut.
  • About 20 seconds in, you may hear the engine tune and significantly change frequencies during operation. Continue the cut for 45-60 seconds.
Your saw is tuned. If it doesn't sound correct, verify it has the correct firmware installed.
Husqvarna service technicians can perform a master reset, though these resets shouldn't be done unless the AutoTune unit has been set incorrectly to compensate for a mechanical failure in the engine, e.g. a broken intake rubber, a cracked muffler, a missing or clogged air filter, or after a major repair of the engine or fuel system.
Additional Resources
Autotune Test Procedures
Husqvarna Autotune's Dealer Diagnostic Tool
nicO
crwdns2935283:004/14/15crwdne2935283:0
15,990 crwdns2915208:0crwdne2915208:0
crwdns2935297:088crwdne2935297:0
Global Fixers crwdns2935289:0Global Fixerscrwdne2935289:0
Community
crwdns2931471:071crwdne2931471:0
crwdns2935297:03,050crwdne2935297:0
Hi Nico,
Thanks for this brilliant instruction. 2 questions: Is it suitable to autotune 3.0? In the full throttle reset: 45 - 60 sec on top when I hear the motor tuning or is 45?- 60 sec total time?
Greets husky123
Husky123 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 78
crwdns2936753:030crwdne2936753:0 360
crwdns2959996:0crwdne2959996:0 13,687
