crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Controller Won’t Power On
The controller does not show any sign of being turned on.
Controller Batteries are Dead
Use a screwdriver to remove battery casing. Check to see if batteries are corroded or dead. If the batteries are in need of replacement, replace them with new AAA batteries. Reattach battery casing and test to see if the controller works. For help with replacing controller batteries, use this guide
Controller Transmitter is Broken
Unscrew the six screws on the back of controller using a J1 screw Philips. Remove the casing and check the circuit board for any damage or disconnected wires. The transmitter is a small circuit board at the top of the controller. The transmitter is green instead of a blue hue of the rest of the circuits. Check transmitter for damage or disconnected wires. For help with replacing controller-transmitter, use this guide
Broken or Disconnected Wires
The Hot Wheels AI Intelligent Race System has a pair of controllers that are frequently used which can result in the disconnection of wires. Remove the six screws on the back of the controller with a J1 Philips head screwdriver. Pop the controller casing loose to expose the inside of the controller and circuit board. Check to see if all the wires are connected and free of breaks. If wires are disconnected, safely reconnect them or replace them as needed. For help with replacing wires, use this guide
Factory Reset
If all else fails, you can return your controller to the original factory settings. Connect the vehicle and push the black, circular button next to the ‘on’ button on the controller. Toggle the steering stick to the left or right until you hear “Factory Reset.” Push the checkmark button located on the front of the controller. Once you hear the “Warning: Factory Reset,” press the checkmark button again to confirm. A series of beeps will play to verify that you have reset the controller successfully.
Controller Turns On But is Unresponsive
When you press buttons with the controller on, the cars don’t respond.
The Hot Wheels AI Intelligent Race System has a pair of controllers that are frequently used which can result in the disconnection of wires. Remove the six screws on the back of the controller with a J1 Philips head screwdriver. Pop the controller casing loose to expose the inside of the controller and circuit board. Check to see if all the wires are connected and free of breaks. If wires are disconnected, safely reconnect them or replace them as needed. For help replacing wires, use this guide
Factory Reset
If all else fails, you can return your controller to the original factory settings. Connect the vehicle and push the black, circular button next to the ‘on’ button on the controller. Toggle the steering stick to the left or right until you hear “Factory Reset.” Push the checkmark button located on the front of the controller. Once you hear the “Warning: Factory Reset,” press the checkmark button again to confirm. A series of beeps will play to confirm that you have reset the controller successfully.
Car Won’t Turn On
Car is unresponsive when switched on.
Car Batteries are Dead
Use a screwdriver to remove battery casing. Check to see if batteries are corroded or dead. If batteries are in need of replacement, replace them with new AAA batteries. Reattach battery casing and test to see if the car works. To replace batteries, use this guide
Jammed Power Button
Power buttons on both the cars and controller of Hot Wheels AI Intelligent Race System are prone to jamming. The power switches are located on both the bottom of the cars and the top of the controller. Move the switches back and forth from on to off position and make sure the switch flips easily. If the switch gets stuck or the light is unresponsive, the switch is jammed. To fix switch jamming remove the top casing of the car by removing the two small screws on the bottom front of the toy vechile. After removing the casing of the car, remove the four J1 Philips head screws on the top part of the body of the car. Next, remove the two small screws over the transmitter with a j0 Philips head. Pop loose the top of the body exposing the circuits of the car. The on/off switch is located below the circuit board. Lift the board and check for debris that may be jamming the switch.
The Hot Wheels AI Intelligent Race System has a pair of controllers that are heavily used and dropped often. This can result in the disconnection of wires. Remove the six screws on the back of the controller with a J1 Phillips head screwdriver. Pop the controller casing loose to expose the inside of the controller and circuit board. Check to see if all the wires are connected and free of breaks. If wires are disconnected, safely reconnect them or replace them as needed. For help replacing wires, see this guide
Car Receiver is Broken
The Hot Wheels AI Intelligent Race System cars are equipped with a receiver that is located on the bottom of the car between both sets of wheels. Debris or damage to these receivers can cause connection problems when using the controller. Check bottom side of the car if no debris or damage is present receivers may need replacement. Receivers are located by removing the top casing of the car. Do this by removing the two screws at the front of the car with a J0 Philips head screwdriver. Pop the casing lose to expose the body of the car. Remove the four J1 Philips head screws on the top part of the body of the car. Next, remove the two small screws over the transmitter with a j0 Philips head. Pop loose the top of the body exposing the circuits of the car. Lift the circuit board and wheel bearings to expose the transmitter. Check transmitter for damage or disconnections. If no harm is present, the transmitter will need to be replaced. To learn how to replace transmitter, use this guide
Car Won’t Drive Straight
The car veers to the left or right when being driven.
Steering Alignment Needs to be Adjusted
With all of the crashing that these cars encounter, their steering will sometimes need to be adjusted. To adjust the steering, connect the car to the controller and press the black circular button next to the ‘on’ button. Toggle the steering stick left and right until you hear “Adjust Steering.” Push the checkmark button and follow the voice prompts. Drive the car forward and backward without steering to see if it turns left or right on its own. Correct the steering by pushing the steering stick in the opposite direction of which the car turned. Each time you turn the steering stick left or right; a ‘beep’ will confirm that you’ve adjusted the steering one notch in that direction. Once you are satisfied with the steering, and the car seems to be driving straight, press the checkmark button again.
Wheels Don’t Spin Or Spin Slowly
The wheels on the cars don’t spin or spin very slowly.
Debris is Jammed Between the Wheels and the Car Body
The tires might have dust, dirt or debris stuck between the wheels and the car body. Remove the top casing of the car by removing the two screws on the bottom front side of the car using a small Phillips head screwdriver. Pop the casing from the body and wheels of the car. This will openly expose the wheels and bearings. Use a damp cloth to clean the wheels and bearings.
Unscrew the six screws on the back of controller using a J1 screw Philips. Remove the casing and check the circuit board for any damage or disconnected wires. The transmitter is a small circuit board at the top of the controller. The transmitter is green instead of the blue hue of the rest of the circuits. Check transmitter for damage or disconnected wires. For help with replacing controller-transmitter, use this guide
Volume is Too Low
The exclamations and directions coming from the controllers’ speakers are hard to hear.
Volume Selection is on a Lower Setting
Check the controller to see if it is set to a low volume. Press the “Confirm Selection” which is the blue check button on the right-hand side. Toggle left or right to adjust to the desired volume. Press the “Confirm Selection” again to select volume.
Debris Stuck in Speakers
Blow into the speakers using a dust-off disposable compressed gas duster. If cleaning is unsuccessful, remove the casing from the controller by taking out the six screws on the back of the controller. After removing screws pop the casing lose and inspect the speaker for dust or damage.
Water Damage
If water damage occurs, it is possible to remove the casing of the controller. Take out the six screws on the back with a j1 Philips head screwdriver. Pop the casing loose and leave in rice for a few hours to absorb excess water from the device. Diagnose the vehicle and controller once dry.
Richard
crwdns2935283:002/07/17crwdne2935283:0
36,328 crwdns2915208:0crwdne2915208:0
crwdns2935297:011crwdne2935297:0
crwdns2944067:06crwdne2944067:0
Hi, I have issue with one car. When push turn button the wheels are move first to the right direction but then moves left and right more times as a spring after triggering. Any idea for solution?
Afeher - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I can't make to the “adjust steering” section no matter what does anyone have any idea how can I get into it ?
It only allows me:
-speaker volume
-engine sound
Thou no adjust steering, and when o start the car holding settings it goes.into sensor reading only
Luis Vitorio Cargnini - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hi, I have a problem with one of the controllers. It appears to connect to the car ok but when you select race mode and start to drive or race, the sound of the engines comes on immediately and the car is unresponsive . I also noticed that when you turn on the controller, you don’t get the welcome message and goes straight to “turn on your vehicle”. Batteries are ok. Factory reset didn’t help. Any ideas?
Mark Summers - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Just contact Hasbro/Hotwheels to replace it, in my case there was oxidation on the controllers, once they replaced, all worked fine, but go straight to Hasbro.
Hi my Rc is stuck on drive. As soon as I power it on it just drives straight wont stop and won't respond to the remote.
Maggie C - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 74
crwdns2959996:0crwdne2959996:0 3,895
