Introduction
Hot tub error codes help diagnose issues with a spa's heating, water flow, and electrical systems.
These codes vary by manufacturer but typically indicate problems related to sensors, pumps, or power supply. Below is a general guide to common hot tub error codes and their meanings by popular manufacturers.
Error Codes By Manufacturer
Balboa
Error CodeMeaning
pdPower supply on battery backup
OHSensors reading 112-118° F
OHHOverheat. One sensor has detected 118º F. Spa has shut down.
OHSOverheat. One sensor has detected 110º F. Spa has shut down.
FloImproper flow/pressure switch error
CoolWater temp 20° F below set point
ICEPotential freeze condition
Sn1Hi-limit sensor failure
Sn3Temp sensor malfunction
SnaSensor plugged into jack A fail or not working. Spa has shut down
SnbSensor plugged into jack B fail or not working. Spa has shut down
SnSSensors out of balance. If alternating with temp, may be temporary condition causing the spa to shut down.
HFLSubstantial difference between temp sensors detected. Could indicate a flow problem
LFPersistent low flow problems. (Displays on the 5th occurrence of "HFL" message with 24 hours). Heater is shut down, but other spa functions run normally.
drInadequate flow in heater.
dryInadequate flow in heater. (Displays on third occurrence of "dr" message)
PrWhen spa is first actuated, it will go into Priming Mode
- - -Unknown water temp. Normally displays when first powered up after a refill
StdSpa operating in Standard Mode.
EcnSpa operating in Economy Mode.
SESpa operating in Standard-in-Economy Mode.
ILOCInterlock failure - possible pump/ozone spike
Applied Computer Controls (ACC)
Error CodeMeaning
CoLdTemperature in the spa heater housing is below 40° F. Status of the heater element is unknown. The low speed pump or circ pump will operate continuously until the temperature rises above 45° F
OHOver heat. The spa is at a temperature above 108° . Do not use spa when temperature is flashing or the OH message is displayed
HLoHHi Limit Over Heat. Hi limit sensor is disconnected or shorted or the spa temperature is above 112° F
SEoPSensor open or disconnected. Heater disabled but the spa is operational
SESHSensor short, nonfunctional. Heater disabled but the spa is operational
PSoCPressure switch open with circulating pump
PSoLPressure switch open with low pump
PSoHPressure switch open with high pump.
ToETime out error. Indicates that the system’s heartbeat is out of control and all devices will be shut down, making the spa is unusable. This message will rarely ever occur
Correct Tech Inc (CTI)
Error CodeMeaning
thl/39tempprature probe problem
th2/current temptemp probe problem
th3/39water temp below 39° F
OHwater over 112° F. System will restart when temp drops
hotwater over 112° F. System will restart when temp drops
HLHigh limit switch tripped
Brett Aqualine
Error CodeMeaning
OHTemp exceeds 118° F
FrFreeze condition - temp below 40° F
FLPressure switch failure
EOShorted temp sensor
E1Open temp sensor
E2Shorted hi-limit sensor
E3Open hi-limit sensor
E4Shorted flow switch
E7Improper electrical connection
Dream Maker Spas
​Dream Maker Spas is a prominent manufacturer of rotationally molded spas, having introduced this innovative manufacturing technique to the spa industry in 2001.
Error CodeMeaning
OHOverheat 108° F, spa is deactivated.
FLFlow. Pressure switch not working
SNNon functional high temperature sensor. Heater is deactivated
F24 hours daily filtration
F48 hours daily filtration
F612 hours daily filtration
FCcontinuous filtration
EasyPak
Error CodeMeaning
CCelsius
CLCurrent Time of Day
ECduEcono Mode Duration
EconEcono Mode Turn On
FFahrenheight
FlduFilter Cycle Duration
FlonFIlter Cycle Turn On
FLCPressure Switch Alarm
FLOPressure Switch Alarm
FrEEFreeze Protection Alarm
HLHigh Temperature Alarm
LocPanel / Keypad Locked
PrHTemperature Sensors Alarm
PrrTemperature Sensors Alarm
TuTemp Set
Gecko
Error CodeMeaning
AOHTemp in Equipment compartment too high
FLOPressure switch failure, switch open
FLCPressure switch failure, switch closed
FrEPossible freeze condition. Can also make itself known through a Flashing Display, 3 Flashing Dots, or 3 Flashing Dots & LED.
HLSensor measuring 119F
PrrTemp sensor failure
PrhHi-limit sensor failure
SP-HRhardware error
SP-BRbreaker setting to low
SP-INInput voltage low
SP-F1,F2 or F3Fuse 1,2 or blown
SP-OTTemp inside skirt high
SP-OHWater temp over 112F
RH-HRHeater Hardware error
RH-NHHeat attempted & failed
RH-NFNo flow in heater
RH-NCComm error to Pack
RH-HLHeater Hi Limit
P1, P2 or P3-ERPump 1,2 or 3 failure
CP-ERCirc pump failure
BL-ERBlower failure
O3-ErOzone error
A1/A2-ERAux. system error
FN-ERFan failure
FB-ERFiber optic failure
SC-ERSystem learning failure
Sn1Nonfunctional high temp sensor.
Sn2Nonfunctional temp sensor.
FL1Water flow problem, pressure switch malfunction. Check for low water level and ensure pump is primed. Check for clogged filter
FL2Pressure switch problem. Switch closed while pump is deactivated
COLCool condition. If water temp drops 20ºF below set temp, low speed pump and heater activates to bring temp within 15º of set temp
ICEFreeze condition. 55ºF detected. Low speed pump and heater will activate until spa reaches 65ºF
OHHigh temperature condition, has reached 110ºF. Low speed pump (and air blower if equipped) will activate to lower temp
- - -"Watchdog". Water temp has reached 118ºF.
Jacuzzi/Jacuzzi Whirlpool
Error CodeMeaning
OHOverheat Protection (Heater is deactivated, pumps low speed is activated)
COOLtemp 20° F cooler than set point
FLO*Flow Switch (heater is deactivated. Pump may also be deactivated)
FLO2Closed or shorted flow switch on system startup
HoldPanel pressed too many times in a short period of time
HOTCircuit Board temp exceeded acceptable limit
ICEFreeze protection.No action is necessary
I CE2Freeze protection.No action is necessary
PnLCommunication error between the panel and circuit board
- - - -"Watchdog" problem detected
Sn1Open/Shorted sensor
Sn3Open /shorted sensor
FLO2Closed/shorted flow switch at startup
Hercules
Error CodeMeaning
OHSpa temp exceeds acceptable limits
FLOFlow problem
ICEFreeze condition detected
SN1Hi-limit sensor failure
SN2Temp sensor failure
Hurricane
Error CodeMeaning
PSFlow or pressure switch failure
SHShorted sensor
OPOpen Sensor
LOTemp below 60° F - freeze
HLTemp above 118° F
Pinnacle Spas
Error CodeMeaning
OHTemperature has exceeded 110° F
SNSensor failure
FLFlow/pressure switch stuck in closed position
Spa Quip
Error CodeMeaning
err 1 (H20)Prime Failed
err 3Stuck Button
err 4No Water Sensor
err 5Over temp
err 6Thermal Cut Out Tripped
err 7Stuck Relay
err 8No Temp Data
01Stuck Button
02No Controller Data
03Temp Sensor
04Water Sensor
05Spa Over Temp
06Heater Thermal Cut Out
07Stuck Heater Relay
09Water Prime Failed
Hydro-Quip
Error CodeMeaning
CCelsius
ECduEconomy Mode Duration
EconEconomy Mode Turn On
FFahrenheit
FlonFilter Cycle Turn On
TuTemperature Set Celsius
TuTemperature Set Fahrenheit
Sundance
Error CodeMeaning
FLO/FL1/FL2Flow/Pressure switch malfunction
HoldPanel buttons pressed to many times/quickly
HOTPCB temperature above acceptable limit - air blower on
PnlCommunication between PCB and panel interrupted
Sn3Temp sensor failure
- - -"Watchdog" problem detected (possible temp /hi-limit error)
Vita Spas
Error CodeMeaning
HiLiWater tem over acceptable limit
BJ2PPump/Blower purge - normal condition
FPFreeze protect mode - temp under acceptable condition
SS=0;SS=S;LS=O;LS=SMultiple causes; open sensors, bad connection or voltage
Pinnacle
Error CodeMeaning
SNSensor failure
Spa Builders
Error CodeMeaning
Sn1Nonfunctional high temperature sensor. Heater is deactivated.
Sn2Nonfunctional temperature sensor. Heater is deactivated.
FL1Water flow problem, inhibited or pressure switch malfunction. Check for proper spa water level and ensure pump is primed. Check for clogged filter.
FL2Pressure switch problem. Switch closed while pump is deactivated.
COLCool condition. If water temperature drops 20°F below set temperature, low speed pump and heater activates to bring temperature within 15° of set temperature.
ICEFreeze condition. 55°F detected. Low speed pump and heater will activate until spa reaches 65°F.
OHHigh temperature condition, has reached 110°F. Do not enter the spa. Low speed pump (and air blower if so equipped) will activate to assist in lowering temperature.
- - -"Watchdog". Water temperature has reached 118°F. Entire system is disabled. Contact qualified service technician.
Vita Spas
Error CodeMeaning
HiLiWater temp over acceptable limit
FPFreeze protect-temp under acceptable condition
SS=0; SS=S; LS=O; LS=SMultiple causes; open sensors, bad connection to panel, improper voltage, etc.
Jacob Mehnert
crwdns2935283:010/18/21crwdne2935283:0
50 263 crwdns2915208:0crwdne2915208:0
crwdns2935297:052crwdne2935297:0
iFanatics crwdns2935289:0iFanaticscrwdne2935289:0
Community
crwdns2931471:070crwdne2931471:0
crwdns2935297:01 152crwdne2935297:0
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 84
crwdns2936753:030crwdne2936753:0 345
crwdns2959996:0crwdne2959996:0 3,366
