crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
If your Hoover Power Path Deluxe FH50951 is turned on, the vacuum seems to work, and fluid is dispensing correctly, but it appears the carpet you are cleaning is not being scrubbed, follow this troubleshooting guide.
Belt Needs to be Changed
If the brush rolls do not appear to be stuck, or jammed, then the drive belt which spins the brush rolls when the device is powered on should be replaced. Also, over time the belt may degrade and lose the tension required to spin the brush rolls. Hoover Power Path Deluxe FH50951 Belt Replacement
Brush Rolls are Jammed
Debris, hair, and other fibers may be lodged between, or wrapped around the brush rolls, preventing them from spinning. With the device turned off and unplugged, carefully check for, and remove obstructions which are preventing the brush rolls from turning. In some cases, the brush rolls may need to be replaced, you can use this guide to replace the brush rolls. The Brush Rolls could be altered or damaged due to a blockage. Follow this guide to help replace the brush rolls: Hoover Power Path Deluxe FH50951 Brush Roll Replacement
Jon-Erik Hylle
crwdns2935283:010/31/24crwdne2935283:0
259 crwdns2915208:0crwdne2915208:0
Cuesta, Team 60-1, Krynen Fall 2024 crwdns2935289:0Cuesta, Team 60-1, Krynen Fall 2024crwdne2935289:0
CUESTA-KRYNEN-F24S60G1
crwdns2942667:0crwdne2942667:0 179
