crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Blade won’t spin
Propollers will not rotate normally or at all when starting the drone.
Software/Firmware Update
Make sure that your drone's software and firmware are up to date. Sometimes, updates can address performance issues related to propellers. This can be adressed by going into the drone's app, within settings, and checking to see if their the drone is on the current updated version or if there is any updates that is needed to be downloaded
Debris Obstruction
Check to see if there is any debris or waste preventing the drone from taking off. The debris can be hard to see at first glance, if you notice any, remove them and by lightlty blowing it off if it is near the surface or picking it out with small tweezers if the debris is deeper near the internals. If the issue persists try replacing the propellors with this guide.
Won’t turn on
The drone does not activate once manually pressing the power button.
Low Battery
Check to ensure drone is charged. If it isn't, simply charge the battery bank back to one hundreed percent and this should hopefully solve the issue.
Hanging Battery
If the battery is slighlt out of place and isn't securely locked in the battery compartment within the drone make sure the battery is fully pushed and locked in.
Heating Issue
Check if the drone is overheating, if so, make sure to turn off the drone and leave it in a room temperature environment for around 30 minutes to cool down. Aftertwards, attempt to fly the drone again. If the issues keeps on persisting, try to replace the battery with this guide.
Blades won't open
A pair of drone propellers are stuck in place and can not be separated.
Blades stuck on each other
Be sure to open blades correctly by opening the bottom arm first then the one at the bottom or else blades will be stuck. If the issue keeps on persisting, then the arm may be damaged, in that case, try replacing it with this guide.
Camera won’t work
Camera won’t show a clear image or no picture at all.
Inspect camera lens for dirt or debris
If there is some dirt or debris on camera lens, take a dry cloth and clean the debris off thoroughly as a dirty lens could cause problems with image and quality of camera.
Reset drone
If there is still errors with the camera even after you inspect and clean for debris, power the drone off and on again to reset the device.
Drone only flying forward
Drone flying disproportionately in one direction.
Excess joystick movement
Use the button on the drone to cut excess movement in one direction. If joystick is still drifting clean with isopropyl alcohol, you might need to fully replace joystick.
Uncalibrated gyro
Calibrate the gyro before taking off to ensure the drone is stabilized during flight. To calibrate rotate the drone horizontally and vertically along all three axis. Follow the on screen prompt to finish the calibration .
Sokudam
crwdns2935283:002/08/24crwdne2935283:0
392 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 4-5, Harold Spring 2024 crwdns2935289:0University of North Texas, Team 4-5, Harold Spring 2024crwdne2935289:0
UNT-HAROLD-S24S4G5
crwdns2936753:030crwdne2936753:0 52
crwdns2959996:0crwdne2959996:0 1,586
