crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Humidifier not powering on
The power light is not turning on
Faulty Battery
If the device is not plugged in or charged, plug the device in and check to see if the power lights come on. Check the outlets, circuits, and fuses. If the battery is still not charging and the power light turns on, the batter will need to be replaced.
Humidifier not releasing water
Water/Mist not being released when placed in the humidifier and turned on
Low Water Levels
Check the water tank for low water levels and refill.
Bad Wick
Check the wick and soak for five minutes, then reinstall, or replace the wick
Humidifier producing bad odor
Odor when powered on and in use
Contaminated Water
With a new unit, an odor can be apparent. Check to see if the tank water is dirty or old. The water was contaminated in the humidifier as sterilized water can't have an odor. Replace the water tank and clean the tank.
Humidifier producing loud noises
The humidifier makes loud noises when it is turned on
Uneven Surface
The humidifier could be producing loud noises due to it being placed on an uneven surface. Try moving the humidifier to a table or any other flat surface.
Humidifier leaking water
Humidifier leaks water when water is placed inside the tank
Faulty Tank Cover
Make sure the cap is screwed on tightly to prevent any water from potentially escaping. If the humidifier is leaking water from the bottom, you will need to replace the piece or cover the crack where the water is leaking from.
Juan Velasco
crwdns2935283:010/30/23crwdne2935283:0
159 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
UMass Dartmouth, Team 3-6, Konn Fall 2023 crwdns2935289:0UMass Dartmouth, Team 3-6, Konn Fall 2023crwdne2935289:0
UMASSD-KONN-F23S3G6
crwdns2936753:030crwdne2936753:0 44
crwdns2959996:0crwdne2959996:0 1,162
