crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Unwanted Picture Arrangement
The projector's image may be too small or large on the screen, or it may appear to high and angled to the left or right.
Zoom and Focus Adjusters Are Off
Make sure the zoom and focus adjusters aren't broken. If not slide the first handle left or right to your desired size. If the image is now blurry go to the second handle and slide it left or right until the image is clear. If none of this work, you can go to the remote and click zoom + or - for desired size. You can also go to focus and click + or - for a clearer image.
Feet Adjusters
Make sure the rubber feet adjusters aren't damaged or missing. If not turn one foot on each side right to shorten or left to lengthen to adjust the height. And you do the same to adjust the angle of the image that is presented on the screen.
Blue Screen
The image displayed is blue on the screen.
Improper Connection Port
If you have any wires in the wrong place, it can cause a blue screen.
Connected Device is Powered Off
If the device that you have is off or is in resting mode. This can cause a blue screen, so simply turn the device on or shake the mouse to turn it on.
Overheating
The projector is hot and is turning off, it also has a red blinking light as an indicator.
Poor Ventilation
If you have your projector next to another object or by a wall it can cause it to overheat because the fans aren't providing proper air flow. To fix this you can simply move it to a more open area. The same happens when you have a buildup of dust by the vents it can cause overheating. to fix this you simply dust the projector off every month.
Faulty Light Bulb
If you have a low-quality light bulb in your projector, it can cause overheating because it creates more heat than your standard light bulb. To fix this simply unplug the power cord and let the lamp cool down. Next locate the access panel and remove the screws. then pull out the lamp housing and gently pull out the light bulb. Finally reverse the steps that you just took.
No Picture Displayed
No picture displayed is when no image is shown on the screen.
HDMI Problems
Make sure that your HDMI isn't bent by the plug this can cause the picture to not show up. If this isn't an issue, make sure the HDMI wire is securely plugged into your device and projector.
Faulty Light Bulb
Make sure the light bulb isn't blown out. If so, simply unplug the power cord and let the lamp cool down. Next locate the access panel and remove the screws. then pull out the lamp housing and gently pull out the light bulb. Finally reverse the steps that you just took.
Lens Cover is Over the Lens
If you accidentally leave your lens cover over the lens it will result in, you not having an image on the screen. To fix this simply remove the lens cover.
No Sound Output
No sound is playing through the screen.
Unmute on Remote or Low Volume
If you look on your remote you will see a speaker icon button, if you click it, it may unmute your device and fix the problem. If this doesn't work click the + volume to turn up the volume on the T.V.
HDMI Problems
Make sure that your HDMI isn't bent by the plug this can cause the volume to not be there. If this isn't an issue make sure the HDMI wire is securely plugged into your device and projector and it will resolve the issue.
Fabian
crwdns2935283:009/08/23crwdne2935283:0
171 crwdns2915208:0crwdne2915208:0
University of New Orleans, Team 3-6, McDonald Fall 2023 crwdns2935289:0University of New Orleans, Team 3-6, McDonald Fall 2023crwdne2935289:0
UNO-MCDONALD-F23S3G6
crwdns2935297:048crwdne2935297:0
crwdns2942667:0crwdne2942667:0 374
