crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Sound is not working
No sound is heard from speakers.
Extension Malfunction
An extension installed on your Chromebook could be causing the sound to stop working.
Chromecasting
The Chromebook might be trying to Chromecast instead of playing sound directly.
No image from screen
Screen is black or unresponsive.
Is it a Software Problem or a Hardware Problem?
Determine whether the problem stems from the display function or from the laptop’s battery. To test this, connect your laptop to an external monitor. If your computer’s display shows up on this monitor, the problem lies within the screen itself rather than the power source.
Display Malfunction (Software)
The Chrome OS may be missing from your computer or damaged. To rectify this, download the Chrome Recovery Utility app and follow its provided instructions.
Battery Malfunction (Hardware)
Follow these steps to replace your battery.
Cracked Screen
The screen needs to be replaced. Follow these steps to replace the screen.
Battery not charging
I can see no sign of charging, the battery is stuck at 1%, and/or the device is unable to function when unplugged.
Faulty Charger
It is possible that the charger for your device is broken, try to use another charger.
Prolonged Storage
When the Chromebook C11 is stored for a long period of time, it is possible for the batteries to drain past normal levels. In this case, you will need to reset the battery by disconnecting it and reconnecting it.
Bad Battery
The battery may need to be replaced. Follow these steps to replace the battery.
Touchpad won’t work on startup
The touchpad won’t respond to my touch after I turn on the computer
Software is Faulty
It is possible that software settings are responsible. In this case a powerwash or hard reset can fix the issue.
Hardware is Faulty
If a powerwash or factory reset does not fix the touchpad, it may be physically disconnected from the computer. In this case, you will need to take the laptop apart and physically connect it.
Keyboard won’t respond
Some or all keys will not respond when typing.
First, perform a hard reset on the computer.  If this doesn’t work, you can try logging in as a guest to see if an extension or app is causing the keyboard not to respond.  If the issue still persists, you likely have a hardware problem.
Software Problem
An app or extension may be causing the keyboard to lose function.
Hardware Problem
The keyboard or connecting wires may need to be replaced.
Alexander Burrell
crwdns2935283:010/09/18crwdne2935283:0
457 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G3, Leahy Fall 2018 crwdns2935289:0USF Tampa, Team S1-G3, Leahy Fall 2018crwdne2935289:0
USFT-LEAHY-F18S1G3
crwdns2944067:05crwdne2944067:0
I changed battery now battery is working fine however i dont c any battery indication.
cruel_443 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My microphone does not work while the chrome book is opened fully. While facetiming, the screen has to be closed halfway for my microphone to function. Also the screen will only illuminate when I open the chrome book very slowly.
s.agromley01 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
It is the connection from the motherboard to the LCD Screen and the camera microphone module. In order to fix this, you will need an LVDS cable.
John Gibson - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
It is saying chrome OS is missing or damaged please insert a recovery USB stick or SD card
Micki Hughes - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Chromebook tells me to up-date browsers, but how do I up-date?
Perry Thibodaux - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2942667:0crwdne2942667:0 3,096
