crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Audio Distortion Comes from the Speaker
Loud buzzing noise when the speaker is disconnected
Loose Connections
Ensure that no connections have been pulled loose. If they have, reconnect them, making sure to do so the right way. Double-check the power connections from the power supply.
Overheating
Verify if the ventilation is overheating; this may cause the unit to underperform. Turn off the speaker. Let it cool for a few hours then turn the speaker back on and verify if it is still functional.
Small Foreign Objects
Inspect the unit for any signs of dirt or dust; this may cause sound loss. I any of entities are found follow the following steps: 1. Use a microfiber cloth. A regular rag is coarse and may harm your speakers’ finish. 2. Dampen the cloth but do not overdo it. If it is dripping, it is too wet. 3. Move the damp cloth in circular motions in order to prevent streaking. 4. To clean the grilles, simply use a lint roller and move it up and down. 5.Do NOT use chemicals on your Esquire Mini.
The Device Shut Down Suddenly
Device turns off after a couple of minutes of being turned on
Battery Drained
You may have drained the devices battery. Plug the device into a power supply; wait, then test if the problem is fixed.
Components
A defective Field Effect Transistor (FET), a faulty Integrated Circuit (IC). Check properly if each component is attached, in order to find out the root cause of the problem.
Faulty Battery
The battery will not hold its charge or does not announce the battery life. Avoid storing in high temperatures and moist places. Do not leave the device unattended for more than 6 months, because this may cause the battery to stop working.
Charging Battery Failure
Battery won't charge when plugging it
Small Foreign Objects Inside the Charging Port
There might be small foreign objects stuck in the charging port, try to use hair dryer or a way to create air pressure to remove them.
Small Metal Connector on the USP Port
The metal inside the USP port is bent causing inappropriate contact with the USP cable. Try to shut off your device, move the battery out and plug it back on, then turn the device on
Inoperative Stand
The stand is unable to support the device's weight
Defective Spring
Stand does not work when you are trying to pull it out. The spring may be overworn. The whole stand would need to be replaced please refer to the Harman Kardon Esquire Mini External Stand Replacement
Dirt on the device's joint
There may be debris inside the device’s stand, which obstruct the stand from working
Defective Buttons
Some of the buttons are not responsive when they are pushed
Charging Lights
When charging the device, the white charging lights are unresponsive. The lights may be damaged and need replacement, please refer to the Harman Kardon Esquire Mini Buttons and Charging Indicator Lights's
Power, Bluetooth, and Phone Buttons
When pressing the buttons, they are unresponsive. This may be because the buttons are damaged. Replace the power, Bluetooth and, phone buttons.
Volume Buttons
When trying to adjust the volume settings in the device, there is no response. This could indicate that the volume buttons need to be replaced.
Audio cuts out "randomly" with the audio cable
While using the audio cable (ex as external speaker for a PC) the audio cuts out and it looks random but it is not.
For the record is the same behavior with or without USB charger.
Is not random
When I listen this track on YouTube in a specific volume level in a systematic way it cuts out between 12:15-12:18 and also in many other parts.
If I increase the volume the issue is done but when is not laud the issue is back in a systematic way.
Is not the source audio device
I tried with my kids old JBL speaker that also have wired audio input and it does not cut the audio. Audio also works without issues with the computer integrated speakers.
I tried on my phone using same browser and I was capable to reproduce the issue including to "fixing" it by increasing the volume.
It does not happen while using Bluetooth
No matters if the audio cable is connected or not. The issue does not happen while using Bluetooth, not even is the sound is low.
Hypotheses
This is pure speculation but could be the engineering team focused on Bluetooth and did not optimize the energy saver for wired aaudio usage then low volume is detected as idle and the speaker try to go to sleep but gets awake almost immediately while detecting sound again.
Joshua Handal
crwdns2935283:010/18/17crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
USF Tampa, Team S1-G9, Cagle Fall 2017 crwdns2935289:0USF Tampa, Team S1-G9, Cagle Fall 2017crwdne2935289:0
USFT-CAGLE-F17S1G9
crwdns2944067:030crwdne2944067:0
Mine speaker sound gone bad its very noisy now
Pavs - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Same here… can anything be done?
Ramya Reddy - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Any suggestions??? Same issue…..very frustrating
rosselyg - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have the same problem. Is there anything I could do? or have you identified the cause of the problem? The speaker was working fine but now the sound is horrible
Gilbert Perea - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 43
crwdns2942667:0crwdne2942667:0 16,710
