crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
When using the remote of your Haiboxing 18859, does the RC car dos not respond to the input? Follow these steps to get your RC car and remote properly connected.
Remote and/or Car Not Switched On
Ensure that both the car and the remote are switched on.
Car Battery Dead
Ensure that the RC car is charged. If it isn’t, plug it in to fully charge it.
Remote Battery Dead
The batteries inside of the remote may be dead. If so, replace the AA batteries inside of the remote.
Charging Cable is Broken
The cable used to charge the car may be broken. Try replacing the cable to charge the car. A replacement cable manufactured by Haiboxing can be found here.
Receiver Not Plugged In
Remove the plastic body shell of the car. Check that the red plastic receiver inside of the car is properly plugged in. To see photos of how the RC car receiver should be setup, view the Haiboxing 18859 RC car receiver replacement guide.
Receiver Damaged
The receiver inside of the car may be damaged. To check, remove the plastic body shell of the car to see the receiver. To replace the receiver, follow the Haiboxing 18859 RC car receiver replacement guide.
Remote and/or Car Battery Damaged
The battery of the remote, car, or both may be damaged. These will need to be replaced. To replace the battery of the remote, follow the Haiboxing 18859 remote battery replacement guide. To replace the battery of the car, follow the Haiboxing 18859 RC car battery replacement guide.
NMiedema
crwdns2935283:003/21/25crwdne2935283:0
317 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 6-3, Botvin Spring 2025 crwdns2935289:0UMass Dartmouth, Team 6-3, Botvin Spring 2025crwdne2935289:0
UMASSD-BOTVIN-S25S6G3
crwdns2936753:030crwdne2936753:0 44
crwdns2942667:0crwdne2942667:0 665
