crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Watch Will Not Turn On
Watch doesn’t not appear to turn on after tapping the screen.
Watch is Not Charged
From the back of the watch align the charging port with the metal contacts on the charging pad.
Faulty Charger
Sometimes the problem could be the charging cord. To know if it is not working, try to use the charger on another Huawei Watch or on a device with same charging port. If the charging cord doesn’t work on the other device, consider buying a new cord.
Faulty Circuit Board
If the watch doesn’t charge after the previous steps, there is a big chance the motherboard or the watch battery is faulty. For instructions on replacing the circuit board, see the Replacing a Circuit Board Guide and for replacing battery, see Replacing Battery Guide.
Watch Does Not Read Heartbeat
The watch does not display the heartbeat when wearing it.
Watch is Not Worn Properly
Make sure that the watch is on your wrist strapped up tight in order to read the pulse.
System Crash
There is a possibility that your system has crashed, certain functions on the watch need to be refreshed. Press the button on the back of the charger to reset the watch.
Watch Exposed to Extreme Heat
If the watch is exposed to extreme heat such as being left in sun or from sweating in a sauna the watch will stop working properly.
Watch Does Not Connect Via Bluetooth
The display screen on the Huawei Fit shows a line through the Bluetooth sign.
The Phone Or Watch Has Bluetooth Turned Off
When pairing your phone, and watch both devices must have their Bluetooth capabilities turned on and within range of each other. To connect your phone and watch, the Huawei Fit app must be installed in the device.
Issues Connecting to The Huawei Fit App
If you are having trouble connecting, open the app on the phone to discover the watch and pair there. Make sure the app is open when connecting the two.
Watch is Paired With Another Device
The Huawei Fit and a device should automatically connect to each other when there are in range if they have been previously paired. If you have trouble reconnecting or connecting to a new phone, make sure both the phone and watch are disconnected from any other devices. The Bluetooth capability can be disabled and then turned back on to help them discover each other. Finally, we recommend restarting both your phone and device.
The Touch Screen is Unresponsive
LCD screen fails to detect touch gestures.
Watch Has Low Battery
Liquid crystal display touchscreens require the battery to be charged above a minimum to respond to touch gestures accurately.
Screen is Damaged
The screen might be damaged or out of alignment. If the battery is fully charged and the screen is still unresponsive the screen must be replaced. If the screen requires excessive pressure to detect touch gestures the screen might need repair. For instructions on repairing or replacing screen, see the Screen Replacement Guide.
Damaged Circuit Board
Most of the settings in the watch require access to the firmware on the motherboard. If some settings are not detecting touch, then there might be a problem with the circuit board connections or ROM chip. When the screen does not respond to any gestures there must be a problem with the motherboard and will need to be replaced. For instructions on replacing the circuit board, see the Replacing a Circuit Board Guide.
Vibrating Motor is Not Working
The watch does not vibrate when there is a new notification.
Notification Alerts Are Turned Off
If you are not receiving notification alerts then your watch might be set to not receive notifications. To fix this issue go to the settings feature on your paired device and turn notifications on for the Huawei Fit App.
Faulty Motor
If the watch does not vibrate when receiving a new notification then the motor might be defective and will need to be repaired or replaced. For instructions to repair or replace the motor, see Replace Motor Guide.
Nicolas Hempe
crwdns2935283:002/15/17crwdne2935283:0
1,516 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-3, Sullivan Spring 2017 crwdns2935289:0USF Tampa, Team 1-3, Sullivan Spring 2017crwdne2935289:0
USFT-SULLIVAN-S17S1G3
crwdns2944067:053crwdne2944067:0
Huawei fit 962
Bluetooth is not switching
Help
How to make it on
K G Raj - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Huawei fit 962 Blutooth not switched on, Remaining functions are working
Within a four days vibration not working
Madhu - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Within 4 days my Huawei fit notifications vibrant not working
I have a Huawise fittness tracker watch and was working fine. Yesterday the screen stoped working and the watch has the green light flashing and vibrating. It has also disconnected from the app. I cant get anything up on the screen.
Any ideas?
Thanks in advance for any help
llyrgwyndaf@gmail. - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 113
crwdns2942667:0crwdne2942667:0 45,142
