Dead Phone
No matter what buttons you push the phone will not turn on.
Battery is dead
If your phone won't turn on odds are your battery is dead. Try charging the phone for a minimum of 1 hour and turning the phone back on. If that does not turn the on the phone you need to replace you battery with a new one.
LCD is not Working
The phone is not responding to your commands.
Power Cycle Phone
If you phone is not responding to your commands when you touch the screen, try turning off the phone, wait a couple of minutes and then turn it back on. If that does not work your LCD screen needs to be replaced.
Warped Screen
Screen does not look right
Screen is blurry
If parts of your screen are blurry, try turning your phone on and off and see if that fixes it. If it doesn't your cover the the LCD needs to be replaced.
Buttons not working
If the phone does nothing when you push a button
Sticky Buttons
If the phone does not respond when you push a button they might be sticky. Try taking a Q-tip dipped in rubbing alcohol and clean the area around the buttons in an attempt to clean it. If that does not work, your buttons need to be replaced.
Jake Devincenzi
crwdns2935283:004/18/11crwdne2935283:0
119,603 crwdns2915208:0crwdne2915208:0
crwdns2935297:057crwdne2935297:0
I have a HTC pure mobile.it's brightness is very low.some times it's brightness going high and low.my technician said that problem is voltage to display on main board.I have replace a new display.but problem is same.now we need circuit diagram for check inverters voltage to fix it.
please can you give me a circuit diagram for htc pure or Touch Diamond2?
its is big help for me to fix it.
I am waiting for answer ASAP.
Nishanth - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 45
crwdns2959996:0crwdne2959996:0 1,096
