crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
This troubleshooting page is currently in the preliminary writing stage. For more troubleshooting help, reference this page.
Sound is Muffled or Absent in One or Both Speakers
Speakers aren't emitting sound or the sound is muffled.
Speaker Damaged
Small debris can clog and muffle the speaker grills. Inspect and clean the speaker grills with short bursts of compressed air or a finely-bristled brush, if visible debris is present.
Check for any software conflicts with any installed third-party applications and remove them as necessary.
If sounds still does not return after external cleaning and eliminating possible software conflicts, debris might be inside the device, requiring a more thorough internal cleaning and/or replacement of the speaker.
Sound is Crackling
Speakers make a crackling sound when audio is on.
Poor Audio Quality
Playing poorly compressed audio at high volumes can cause a crackling effect that might incorrectly suggest a problem with the speakers. Ensure that the problem is for all sound before assuming any speaker defect.
Speaker Damaged
Crackling sound can also be a symptom of water damage. Ensure the device is dry and, if the problem persists, replacement of the speaker may be necessary.
Headphones Not Working
There does not appear to be any sound coming from the headphones when they are plugged into the phone.
Audio Jack Damaged
Ensure the headphones are working properly with other devices and are compatible with the HTC One M8. The HTC One M8 has a standard 3.5 mm headphone jack.
If the problem is persists only for the HTC One M8, replacement of the headphone jack may be necessary.
Screen Does Not Auto-Rotate
Phone will not transition from portrait to landscape mode when phone is rotated.
Incompatible Application
Not all Android applications are designed with screen rotation in mind. Verify that the problem is consistent among all applications.
Automatic Screen Rotation is Turned Off
  • Go to settings
  • Go to Display & gestures
  • Select Auto-rotate screen option
G-Sensor Needs Calibration
  • With two fingers, swipe down on the status bar
  • Press Settings button (cog icon)
  • Go to G-Sensor Calibration
  • Place phone on flat surface and calibrate
  • When calibration is done, press OK
Screen is Not Functioning
The phone's touch screen is either damaged or isn't responding to the users touch.
Screen is Cracked
The display is made with Corning Gorilla Glass and is damage resistant. Most scratches will be surface level and cosmetic only. If operation is impaired, proceed with the replacement of the screen.
Screen is Unresponsive
Background applications might use up too much memory and slow down the phone until it is unresponsive.
  • Restart the phone.
  • Go to Settings
  • Go to Accessibility
  • Go to Services
  • Select Turn off all apps
Phone Won't Charge
Phone does not appear to be charging when plugged into charger.
Charger Issues
Verify that the issue is with the phone and not with the power source or charger cable. The HTC One M8 needs a micro-USB charger.
Mirco-USB Port Problems
Ensure that the phone does not have debris in the mirco-USB port but cleaning it out with small bursts of compressed air. If the problems persists then the port may be damage and a replacement will be required.
Phone Won't Power On
The phone does not power on when the power button is pressed.
Phone Has No Charge
The phone may have simply lost its charge. Plug in the charger to verify that it isn't the problem. If the problem persists then boot the phone into safe mode.
  • Press and hold the power button until the Phone Options prompt appears
  • Release the power button
  • Press and hold the Power off until the 'Reboot to safe mode' option appears
  • Press Restart
If the phone can successfully boot into safe mode than one of the applications is preventing a successful boot up.
Phone Won't Hold Charge
The device discharges quickly
Phone Charges Very Slowly
The battery may need to be re-calibrated.
  • Shut off the phone
  • Plug the charger in and let it charge for ten minutes
  • Hold down the power and the volume down button for two minutes while it boots back up
Phone Loses Charge Very Quickly
Certain applications may be using too much power.
  • Go to Settings
  • Go to Power
  • Verify that no applications are using excess amounts of power.
Camera Not Functioning
The camera displays no image when activated.
Visible Damage
There may be several scratches on the protective film located on the camera. A replacement of the film may be necessary if the scratches are obscuring the image. If the scratches go past the protective film then a replacement of the camera may be necessary.
SD Card Not Functioning
SD Card data cannot be accessed.
Wrong SD Card
Ensure that SD Card is a Micro-SD card. Attempting to use a different SD card could damage the phone.
Corrupt SD Card
Before using the SD card make sure that you properly eject it
  • Go to Settings
  • Go to Storage
  • Go to Unmount
Verify with whether the SD Card is corrupt by using it on another device.
No Cellular Service
The device does not have connection to the carrier network.
SIM Card Not Functioning
Faulty SIM card installed in device. Consider replacing with new SIM card from your wireless carrier.
SIM Card Slot Contains Debris
There SIM card may contain debris. Apply some rubbing alcohol and gently clean the SIM Card off.
Wrong SIM Card
Ensure that the SIM Card is the right one for the HTC One M8. The HTC One M8 supports the standard Nano SIM Card.
Mitchell Keller
crwdns2935283:004/14/15crwdne2935283:0
1,735 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 5-9, Maness Spring 2015 crwdns2935289:0Cal Poly, Team 5-9, Maness Spring 2015crwdne2935289:0
CPSU-MANESS-S15S5G9
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 1,362
