crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Desktop Won't Turn On
No humming fan noise and no light on the front panel signaling that the desktop is on.
Hard Reboot
Hold the power button for ten seconds
Check to Make Sure That the Desktop is Plugged In
Double check to make sure you have the right connection plugged into the correct port on the desktop and into an outlet.
Faulty Cable
Check that the cable has no exposed wires or no distortion to the cable; check prongs.
Check Power Outlet
Test appliances that work with the outlet. If the outlet doesn't work check the circuit breaker.
Bad Power Supply
Click this link to view how to remove the power supply from the computer.
HP rp5700 Power Supply Replacement
Power on But No Present Image
The lights on front panel are flickering and/or solid and you can hear the fan humming.
Bad Connections
Make sure the blue cables are plugged into the correct ports of the computer and monitor.
Bad Monitor
Plug in a working device into the monitor to make sure the monitor is working.
Bad Motherboard
If your monitor is still not working, click on the link to replace your motherboard.
HP rp5700 Repair Motherboard Replacement
Windows Loading Screen Does Not Appear
The hp loading screen and a black screen with writing appear.
Reset BIOS (Preloaded Firmware on motherboard)
BIOS settings can be reset by following this guide and removing/replacing the internal motherboard battery.
HP rp5700 Repair iOS battery Replacement
Bad Hard Drive
Faulty hard drives can range from not working at all to operating slowly. Click here to replace the hard drive.
HP rp5700 Hard Drive Replacement
Mouse and Keyboard are Not Working
Unable to move the cursor and/or click on anything and the keyboard functions don't work.
Check the Connections
Make sure the USB connections are plugged in correctly.
Brocken Mouse and Keyword
Test the mouse and keyboard into a working computer to check to see if the devices are working.
Bad Ports
Use another working device to test the port by plugging in the working device into the port.
Replace the Motherboard
If the ports aren't working, follow the link to replace your motherboard.
CD Drive Does Not Work
Either the computer isn't reading the disk or the drive doesn't function.
Disk Not Reading or Tray Not Opening
Restart the computer and see if the problem is fixed. If not, click this guide to see how to remove/replace the optical drive.
HP rp5700 Optical Disk Drive (CD Drive) Replacement
External Device and Connection Problems
Audio isn't working or USB and Ethernet connections are failing.
Check Connections
Make sure that respective devices are connected to the proper ports.
Audio cables should match their desired colored ports.
Update Drivers
Make sure all of the software updates for the computer, such as the audio drivers, are up-to-date. These links can be found on this manufacturing website.
Faulty Devices
Double check that the speakers and the ethernet cable, as well as other connections, are working by plugging them into a working computer/laptop.
Faulty Motherboard
If none of these solutions solve your problem, link here to replace the motherboard. HP rp5700 Repair Motherboard Replacement
If you using the phone cable, click this guide to replace the correct component card.
HP rp5700 Extra Internal Cards Replacement
Alyssa Briones
crwdns2935283:001/21/14crwdne2935283:0
1,765 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-23, Maness Winter 2014 crwdns2935289:0Cal Poly, Team 6-23, Maness Winter 2014crwdne2935289:0
CPSU-MANESS-W14S6G23
crwdns2935297:0108crwdne2935297:0
HP RP5700 5 times beep, red light blink and computer dont turn on how can I solve this problem?
mehmetd_064 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 4,215
